cancel
Showing results for
Search instead for
Did you mean:
A question about the Intel NVMe SSD P3700 thermal throttling
Esteemed Contributor III
Hi,I have a question about the Intel NVMe SSD P3700 series specification document.
In page number 26, what is the exact meaning of descriptions of Byte 0 and Byte 1-4? (please see the picture below)
Is integer percentage in Byte 0 means the ratio of slow down due to the thermal or something?
What is throttling event count in Bytes 1-4 mean?
I need more clear descriptions for them.
Thanks for your kind support in advance.
Jaemin
10 REPLIES 10
Hello Jaeminyx,
It is really hard to give you any explanation about this when you have removed the heatsink from the SSD, this is not going to operate as it should if you remove parts from the disk.To help you further, we would like to bring this to our engineering department and check what they have to say about it, however, keep in mind they may not provide support to this drive.We will keep you posted.Regards,NC
