Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
ASUS IMPACT VIII & Intel 750 1.2 Tb Drive Not Detected
RRand2
I'm using the U.2 connector on the Maximus Impact to connect a 750 1.2 Tb SSDPE2MW012T4R5
ASUS Device report indicates that they support SSD DC 750 Series-400GB. I was trying to consolidate all my storage into one device.
When the machine opens bios the drive is not recognized. When I boot to win10, it finds the driver that I downloaded from intel but says it's not compatible with my hardware.
This is my last stab before having to return this beautiful drive.
Can this be made to work? Am I missing something? why would this board support the 400GB but not the 1.2Tb?
Any insights would be greatly appreciated, thank you.
Some Additional Info: CMS is enabled and primary boot option is set to UEFI only.
Community Manager
rswillis,
We understand you would like to install your Intel® SSD 750 Series in your computer, which is the Asus Impact VIII.
Please take a look at the following link: http://www.intel.com/content/www/us/en/support/solid-state-drives/consumer-ssds/000005797.html?wapkw... Before You Buy an Intel® Solid State Drive for better understanding and requirements.
At the same time, please check this other link with some tested motherboards: http://www.intel.com/content/www/us/en/support/solid-state-drives/consumer-ssds/000005729.html Tested Compatible Motherboards with the Intel® SSD 750 Series.
However, we would like to investigate on this case and get back to you after some research. If it is possible, we will try to test it here as well and provide you the outcome.
RRand2
Cool, I will hold off on the return till I hear something from your tests. I'm not in a big rush, and certainly this would be a potent combo.
However it turns out, thank you for taking your time. Greatly appreciated
DStuk
Intel 750, 1.2TB, U.2, boots just fine for me. Win 10, BIOS 1601
Do not forget to connect SATA power connector
Hope this helps
RRand2
I'm embarrassed to say that i actually had a loose connection. the SATA Power connector was not completely seated into the power supply. Fixed this and the drive / mobo works like a charm. Really just an amazing combination. I can't believe how fast this is. So stoked!
Thank you to both ds4 & nestor_intel for helping me w. this!
Community Manager
ds4,
Thank you for providing suggestions to this thread, really appreciate it.
rswillis,
You may want to check the suggestions, however we recommend to verify all this with your OEM.
Community Manager
rswillis,
We are very glad you have this fixed and working like a charm. In case you need further assistance don't hesitate to contact us back again.
Have a nice day.
