cancel
Showing results for
Search instead for
Did you mean:
Abnormal device statistics on a brand new SSD 530
IIRCA4
New Contributor
Hi All,
I just bought a new 120GB SSD 530 yesterday (SSDSC2BW120A4K5, orignal retail package), but the device statistics reported by smartctl seems abnormal:
The SMART values show that the drive was never used -- most are zeros, but some Device Statistics fields are not zero. For example, the "Logical Sectors Written" is 18343505 (8956MiB), and "Logical Sectors Read" is 16762989 (8185MiB), which are not sync with zeroed SMART "Host_Writes_32MiB", "Host_Reads_32MiB". The "Power-on Hours" field also has the same problem.
Does that mean that the drive wasn't correctly reset before shipping? firmware bug? or other issues?
The following are smartctl outputs
$ smartctl -x /dev/sdc
smartctl 6.4 2015-06-04 r4109 [x86_64-linux-3.13.0-43-generic] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Intel 530 Series SSDs
Device Model: INTEL SSDSC2BW120A4
Serial Number: CVDA513204BC1207GN
LU WWN Device Id: 5 5cd2e4 04bfafa92
Firmware Version: DC32
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Aug 5 23:30:44 2015 CST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x05) Offline data collection activity
was aborted by an interrupting command from host.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 33) The self-test routine was interrupted
by the host with a hard or soft reset.
Total time to complete Offline
data collection: ( 2930) seconds.
capabilities: (0x7f) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x0025) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct -O--CK 100 100 000 - 0
9 Power_On_Hours_and_Msec -O--CK 100 100 000 - 0h+26m+08.080s
12 Power_Cycle_Count -O--CK 100 100 000 - 1
170 Available_Reservd_Space PO--CK 100 100 010 - 0
171 Program_Fail_Count -O--CK 100 100 000 - 0
172 Erase_Fail_Count -O--CK 100 100 000 - 0
174 Unexpect_Power_Loss_Ct -O--CK 100 100 000 - 0
183 SATA_Downshift_Count -O--CK 100 100 000 - 9
184 End-to-End_Error PO--CK 100 100 090 - 0
187 Uncorrectable_Error_Cnt -O--CK 100 100 000 - 0
190 Airflow_Temperature_Cel -O--CK 033 034 000 - 33 (Min/Max 28/34)
192 Power-Off_Retract_Count -O--CK 100 100 000 - 0
199 UDMA_CRC_Error_Count -O--CK 100 100 000 - 0
225 Host_Writes_32MiB -O--CK 100 100 000 - 0
226 Workld_Media_Wear_Indic -O--CK 100 100 000 - 65535
227 Workld_Host_Reads_Perc -O--CK 100 100 000 - 47
228 Workload_Minutes -O--CK 100 100 000 - 65535
232 Available_Reservd_Space PO--CK 100 100 010 - 0
233 Media_Wearout_Indicator -O--CK 100 100 000 - 0
241 Host_Writes_32MiB -O--CK 100 100 000 - 0
242 Host_Reads_32MiB -O--CK 100 100 000 - 0
249 NAND_Writes_1GiB -O--CK 100 100 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x04 GPL,SL R/O 1 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 SATA NCQ Queued Error log
0x11 GPL,SL R/O 1 SATA Phy Event Counters log
0x30 GPL,SL R/O 16 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xb7 GPL,SL VS 16 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log (GP Log 0x03) not supported
SMART Error Log not supported
SMART Extended Self-test Log Version: 0 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Offline Interrupted (host reset) 10% 0 -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testin...
2 REPLIES 2
jbenavides
Valued Contributor II
Hello mhtsai,
Thank you for using the Intel® Support Community. We reviewed the information and would like to inform that there is no problem with your new SSD, the values shown will not affect the expected endurance nor the performance of your SSD.
The best indicators of how much data has been read o written to the SSD are the SMART attributes: Total LBAs Written, Total LBAs Read and Total NAND Writes.
For a detailed explanation of the SMART attributes and other information, you can check thehttp://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-530-sata-spec... Intel® SSD 530 Series (2.5-inch) Product Specification.
Hi Jonathan,
Thank you for your reply. Could you help to explain what circumstance could cause this situation?
Initially, I though that it was caused by the automated SMART test at drive start. According to this thread, the Intel SSD 530 runs automated SMART test at drive reset: /thread/48469 https://communities.intel.com/thread/48469. But, on my two other SSD 730 drives, the SMART test increases "Total LBAs Read" and "Logical Sectors Read" simultaneously.
I also cannot find a smartctl report like my case. So it would be help if you can provide more information.
