Community
cancel
Showing results for
Search instead for
Did you mean:
sdevi
Adding SSD device to HP 8470 P laptop or any Laptop !
Hi ,
I need to fit the SSD 520 Series to my HP Laptpn - Elitebook 2170p or 8470P .
My Qs :
1.What is the Thickness of this SSD 520 Series attached in the pic? - 9.5 mm or 7mm ?
Attached is the pic( sorry I didnt click it otherwise i too could have measured it)
2.What is the system requirement for interfacing above SSD to any laptop(OS - Win7/8, RAM?).
I am disappointed to see that maximum Size of Hard Drive which Can be interfaced is 256 GB and That too on 8570P.
Please advice
Rgds,
Softy
Jose_H_Intel1
According to the picture you posted this is the HP version of the Intel® SSD 520 Series and it appears to be 7mm because it does not have the plastic spacer on top.
The drives are operating system independent; however, we suggest using an operating system with TRIM support (Windows* 7, Windows* 8, Linux*) and a SATA II or SATA III port. We highly recommend verifying with the computer manufacturer for a list of validated SSD models for your system.
