Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Advanced Format and 320 SSD
hi,
i was reading up on the advanced format feature resulting in a 4k sector size
now i ran fsutil fsinfo ntfsinfo c: on my 320 ssd and saw that the sector size is 512
i would have expected it to be 4096
so what's the deal?
tia,
Marc
Community Manager
It is a little confusing but Windows doesn't actually support 4K sectors natively, only 4K sector drives that emulate 512 sector drives (which all current 4K drives do). So, you are seeing bytes per sector (logical) which the drive is reporting for compatibility purposes. You want to look at bytes per physical sector. There is an updated FSUTIL available as explained quite well http://blogs.technet.com/b/filecab/archive/2011/04/26/using-4k-sector-and-advanced-format-drives-in-... here.
Community Manager
i used fsutil and it reported the physical sector size as being 512
so i guess i have the latest fsutil (6.1.7601.17577) (W7 sp1)
so i guess the question remains...
Community Manager
The fact that fsutil reports Physical Sector Size at all means you have the correct version. I just checked a new Intel X25-M using either Windows native driver or Intel RST and I experience the same thing: fsutil reports both physical and logical sector size report as 512. I though all SSDs were 4K physical sector size. So, as you say the question remains...
