Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
432 Discussions
BUG Report - Firmware missing for DC S3110 1.024TB
KO
Just replaced a DC S3110 1.024TB under warranty. The replacement has the old firmware. The only way to update this drive is through the Data Center Tool, which is missing the firmware for the 1.024TB model, similar to how the Intel 545S 1TB firmware was missing from the Intel SSD Toolbox in prior releases. Also, I can't fill out a warranty or support request since the warranty/support system has no listing for the 1.024TB model, nor can find it through the ISN/SN number.
Please update the Data Center Tool so I can update the firmware, which should prevent another RMA.
New Firmware:
LHF002D
https://www.intel.com/content/www/us/en/support/articles/000017245/memory-and-storage.html
Old Firmware:
LHF0B1D
Santiago_A_Intel
Hi KO,
Thank you for your contact to Intel® SSD Support Group on your request for support on your Intel® SSD DC S3110 Series (1.024TB, 2.5in SATA 6Gb/s, 3D2, TLC).
We’ve analyzed your inquiry and it might need some additional research and additional contact with our engineering department; for this reason, we will be escalating this case to our higher support level.
Please notice, due to the nature of this process, at this point, we are not able to provide a time frame for resolution (ETA). This process depends on the queue. However, we will keep you in the loop as the situation develops. Also, feel free to request updates as you deem convenient.
Please don’t hesitate to contact us in case you might have any additional inquires.
Santiago A.
Under Contract to Intel Corporation
Santiago_A_Intel
Hi KO,
Greetings from Intel® SSD Support Group on your request for support on your Intel® SSD DC S3110 Series (1.024TB, 2.5in SATA 6Gb/s, 3D2, TLC).
As told previously, we have escalated this case to engineering; they are requesting your cooperation to send us a screen shot of the error when the tool lists the SSD and when you attempt to update the firmware, please use the latest version of the Intel® SSD Data Center Tool (Intel® SSD DCT), please download latest version from this link: https://downloadcenter.intel.com/download/28639/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=35125.
We will be looking forward to your reply.
Santiago A.
KO
I don't have screen shot of the command window but here was the output from the Data Center Tool I saved to a text file:
- Intel SSD DC S3110s Series BTL************EGN -
DevicePath : \\\\.\\PHYSICALDRIVE1
DeviceStatus : SMART Attribute B8 failed.
Firmware : LHF0B1D
FirmwareUpdateAvailable : The selected Intel SSD contains current firmware as of this tool release.
Index : 0
ModelNumber : INTEL SSDSC2KI010T8
ProductFamily : Intel SSD DC S3110s Series
SerialNumber : BTL************EGN
Santiago_A_Intel
Hi KO,
Thank you for your reply to Intel® SSD Support Group on your request for support on your Intel® SSD DC S3110 Series (1.024TB, 2.5in SATA 6Gb/s, 3D2, TLC).
We have received your information and immediately translated it to engineering; as soon as we have a reply, we will let you know.
Thank you for being an active part of to Intel® communities.
Santiago A.
Santiago_A_Intel
Hi KO,
Engineering is asking for your confirmation, that you’re using the latest version of Intel® SSD Data Center Tool (Intel® SSD DCT)
Current version is Version: 3.0.19 (Latest) from: 3/6/2019 please download it from this link: https://downloadcenter.intel.com/download/28639/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=35125.
Your valuable cooperation is being appreciated.
Don’t hesitate to contact us in case you might have any additional inquires.
Have a nice day
Santiago A.
KO
Yes, that's the version of the Data Center Tool that produced the above output, erroneously indicating the firmware was current.
Santiago_A_Intel
Hi KO,
Thank you got your kind reply; we are going back with engineering and will return to you as soon as possible.
Have a nice day
Santiago A.
KO
Any correspondence about when this firmware is fixed?
Santiago_A_Intel
Hi KO,
Greetings from Intel® SSD Support Group.
We have received a reply from engineering, your point is taken, and we’re thankful for pointing out; we are very sorry about this, Intel is already working on a solution.
Engineering requested to try to proceed with Firmware Update, ignore the messages and try to update the firmware to LHF002D, please attach screen shots of your findings.
Have a nice day
Santiago A.
KO
Here's the command output from the firmware update command. It's the same output as the RMA drive - wrongly indicates the "old" firmware (LHF0B1D) is latest.
Status : The selected Intel SSD contains current firmware as of this tool release.
Santiago_A_Intel
Hi KO,
This is a friendly reminder, you case remains open, awaiting for your kind reply.
Have a nice day.
Santiago A.
Santiago_A_Intel
Hi KO,
Thank you for your reply to Intel® SSD Support Group.
With the information provided, we are escalating this case to our next level of support, in order to request the information needed to fully understand and solve your issue.
Notice that, due to the nature of this process, at this point, we are not able to provide a time frame for resolution (ETA). Please, feel free to request updates as you deem convenient.
If there is anything else we can help you with, please let us know.
Have a nice day.
Santiago A.
Santiago_A_Intel
Hi KO,
In reference to this issue, we need to send you a private message from our advanced warranty support team.
Soon you’ll be contacted via email.
Have a nice day.
Santiago A.
