Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Bad drive?
MarkM
Is my Intel SSD 540s Series 480GB drive going bad?
I have it in a Nuc.  I ran the Intel SSD Toolbox and attached is the result.  It says, “Error: an error was detected reading data from the selected intel SSD....”
In windows explorer, it takes a long time to load a folder with a bunch of videos files in it.  I would see the cursor wheel just keep spinning.  The pc would then freeze after while and I would then do a hard boot.  This is the symptom I’ve seen so far.
If it’s going bad, would it be covered under any warranty?  It’s been several years already.
Mark
JosafathB_Intel
Hello MarkM,
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance with your Intel® SSD 540s Series 480GB. If we infer correctly, we will appreciate it if you can provide us with the following information:
  • The SSU logs.
1-          Go to https://downloadcenter.intel.com/download/25293/ (for Windows*) and to https://downloadcenter.intel.com/download/26735/ (for Linux) download the software.
2-          When finished downloading it, open it.
3-          Attach the file generated by the tool in your reply.
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel®
MarkM
Here you go Josh.
JosafathB_Intel
Hello MarkM,
Thank you for your reply.
We are going to be working on reviewing the log files you shared with us that are related to your Intel® SSD 540s Series.
We will be contacting you back as soon as we have an update or in case further information is required.
Thank you for your patience and understanding.
Josh B.
JosafathB_Intel
Hello MarkM,
Thank you for your patience.
Based on the logs you shared we can not determine any hardware issue related to the Intel® SSD 540s Series and our recommendations are the following:
• We will appreciate it if you can run the firmware update in your SSD to the latest available version using the Intel® Memory and Storage Tool (https://downloadcenter.intel.com/download/29428/Intel-Memory-and-Storage-Tool-GUI-). Section 6.2 of the User Guide (https://downloadmirror.intel.com/29428/eng/Intel-MAS-GUI-1.0.5-User-Guide-342845-001US.pdf) includes the instructions on how to do it.
To update the firmware on an Intel® SSD:
1. Back up the Intel SSD.
Perform a complete system backup on the Intel SSD to make sure no data is lost during the firmware
update process. Intel is not responsible for any data loss that might occur during or after a firmware
update on an Intel SSD.
2. Close all open applications except the Intel MAS tool.
3. Select the Intel SSD you want to update on the home screen.
4. Select Firmware Update.
5. Click Update to update the selected Intel SSD with the firmware version included with this release of
Intel MAS tool. Minimize system use during this operation.
6. Reboot your system once the update is complete.
• After confirming that you have the latest version of the firmware, please follow the steps in the When to Run a Low-Level Format or Secure Erase on Intel® Solid State Drives and Tools to Use article (https://www.intel.com/content/www/us/en/support/articles/000006198/memory-and-storage.html)
*We provide links to third-party tools and sites for your convenience. We don't necessarily endorse the content, products, or services offered there. We don't offer support for third-party tools.
* Perform a complete system and information backup on the Intel SSD to make sure no data is lost during the process. Intel® is not responsible for any data loss that might occur.
We will be looking forward to your reply letting us know the results.
Best regards.
Josh B.
MarkM
HI Josh,
The MAS tool says the my firmware LSBG200 is out of date.  However, I am not able to update the firmware because the button is grayed out.  Please look at screenshot.
Mark
MarkM
JosafathB_Intel
Hello MarkM,
We do apologize we did not receive a notification regarding your reply until today.
Please try to update your SSD firmware by using the Intel® SSD Firmware Update Tool (https://downloadcenter.intel.com/download/29555/Intel-SSD-Firmware-Update-Tool?product=80097)
For a guide on how to use this tool please visit the User Guide (Intel_SSD_FUT_User_Guide.pdf)
https://downloadmirror.intel.com/29555/eng/Intel_SSD_FUT_User_Guide.pdf
Best regards.
Josh B.
JosafathB_Intel
Hello MarkM,
We were reviewing your community thread, which is related to your Intel® SSD 540s Series, and we would like to know if you were able to review our previous post and if you needed further assistance.
Have a nice day.
Best regards.
Josh B.
JosafathB_Intel
Hello MarkM,
We were reviewing your community thread, which is related to your Intel® SSD 540s Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need further assistance, please post a new question.
Josh B.
