Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Best Offset for XP?
Just a very quick question.
I have an Intel X25-V coming today that will be used with XP Pro.
I have read that for SSD drives you need to change the offset as XP sets it to an outdated 63kb which causes severe fragmentation of the drive.
But there is conflicting info all around as to what is best to set the offset to.
It seems it is either a choice betweem 64k, 512k, or 1024k.
Windows 7 sets it at 1024k, but I am seeing discussions for OCZ SSD's saying use 64k or 512k for XP.
As its an Intel drive I have I wanted it from Intel what would be best for XP with this intel drive. So which should I set the offset as?
Community Manager
I use 64 even for win 7 and I have the X25-E 64GB
Community Manager
I'd use the Windows 7 offset of 1 MB (1024 KB). That's the new standard for Windows. While a smaller alignment might still produce the same benefits for a given drive, I don't see how 1 MB could be worse, since it is aligned with all possible smaller choices (which would have to be powers of 2).
Community Manager
True, I tried both 1024 and 64 and saw no difference at least running the: winsat disk
I need to run more benchmarks to be sure though.
Community Manager
Actually in my experience there was no significant difference in performance between properly aligned (e.g. 1024 offset) and misaligned (63) on my X25-M G2 160GB. Benchmarks show only around 2-3% increase. So, why bother?
Community Manager
You are right but the performance with a misaligned SSD will decrease much faster in the long run
