Community
cancel
Showing results for
Search instead for
Did you mean:
JLyam
Bios cannot detect M2 SSD
Jump to solution
Dear Sir/Madam,
I built myself a custom pc just a few days ago. I installed windows 10 home edition 64 bit to the SSD, it was working. and I installed my programs in it.
My build:
windows 10 home 64bit
i5-7500
MSI B250i gaming pro ac
hyperx fury 2400Mhz 8gb x2
intel 600p M2 SSD 256gb
wd blue hdd 1tb
antec eco 2 450w
define nano s
Yesterday when I started my pc and opened a game (league of legends beta client, which was installed in the SSD), it crashed and went blue screen. Then it tried to gather information (I could see the 0% on the blue screen, but it just stayed 0%) and pc rebooted itself. However, it could not find any boot device. When I entered the bios, the M2 slot read "not present". I used recovery USB to recover windows but it installed directly to my HDD. I tried re-flash bios, re-insert the SSD to M2 slot but it just won't detect the SSD.
3 screen captures can be found in this link.
imgur.com/a/j2ZK9
The first one shows my SSD present before my pc went blue screen
The second and third ones are the current status.
Could you kindly advise what to do next?
Community Manager
Hi Javierlyam,
We understand your SSD is no longer detected by your motherboard and it was working fine.
As the previous user suggested if it is possible, could you try to put the SSD in a different system that can handle NVMe* through M.2 GEN3 X4?
As for the pictures, could you confirm the BIOS update is the one in this https://www.msi.com/Motherboard/support/B250I-GAMING-PRO-AC.html# down-bios link?
If by any chance the SSD is not detected as well in a compatible motherboard, please contact our http://www.intel.com/content/www/us/en/support/contact-support.html# @19 support department for further assistance.
NC
KL2
Valued Contributor I
It could be a bad 600p SSD, but I'd try to see if it's detected in another PC first, assuming you have access to another PC with an M.2 PCIe NVMe capable slot.
I also find it strange that your ME Version in the BIOS is 0.0.0.0
Community Manager
Hi Javierlyam,
NC
JLyam
I will try to get someone to help test using another compatible motherboard. Yes I confirm it is the bios version I used to flash.
Community Manager
Hi Javierlyam,
Thanks for replying back.
We hope you can try the test but remember that in case you don't have any other system available you can always contact our support department for further assistance.
NC
JLyam
My retailer helped figured out that my ssd is working with another motherboard. It's my motherboard not detecting the ssd. They had replaced it for me. Thanks NC and Gize for your kind advice.
Javi
