hors au moment de lancer le clonage ce dernier ce réalise en 2 secondes (Chrono) et me demande de redémarrer et d'enlever le disque dur Source pour qu'il puisse démarrer sur le disque dur cible, hors le disque dur cible n'a reçut absolument aucune donnée et est donc toujours vide. Que faire ? Merci d'avance !
Hello JDELA22,
Thank you for contacting Intel® Memory & Storage Support.
As a friendly reminder, our service is provided in English only.
As we understand, you need assistance with your Intel® SSD 5 Series (480GB) and the Intel® Data Migration Software. If we infer correctly, please provide us with the following troubleshooting information as stated in the “User Guide for Intel® Data Migration Software” (https://www.intel.com/content/www/us/en/support/articles/000020923/memory-and-storage.html) article:
o On the main program, window click the question mark symbol and select the Generate system report option.
o On the Windows Start menu, click All Programs -> Intel -> Data Migration Software -> Tools and
Utilities -> Intel System Report.
o Press CTRL+F7. Note that you can use the key combination even when Data Migration Software is performing any other operation.
After the report is generated:
o To save the generated system report to file, click Save and in the opened window specify a location for the created file.
o To exit the main program window without saving the report, click Cancel.
1. A description of the exact sequence of steps performed before you encountered the issue.
2. A crash dump. For information on how to collect such a dump, see the Intel Support Knowledge Base (KB) article at http://kb.acronis.com/content/27931.
We will be looking forward to your reply including this information.
Josh B.
A Contingent Worker at Intel
Third-Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use, you agree that you must evaluate, and bear all risks associated with, the use of any third-party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site-specific terms.
Good evening, I thank you for your answer, and apologize for the first post in French,
Once the software is open, I go to tools, Clone, choose the hard drive C source and E target and I start cloning, then a new window opens cloning begins and ends in less than 2 seconds. Then the software tells me to restart and unplug the source drive before it can boot to the target hard drive. While the target hard drive is still empty.
Hello JDELA22,
Thank you for your reply.
We are going to be working on reviewing the logs you provided that are related to your Intel® SSD 545s Series and the Intel® Data Migration Software. We will be contacting you back as soon as we have an update or in case further information is required.
Thank you for your patience and understanding.
Josh B.
Hello JDELA22,
Thank you for your patience.
After reviewing the logs and the information you provided our recommendation is the following:
We will be looking forward to your reply.
Josh B.
Disclaimer: Intel is not responsible for lost user data. Before you proceed, back up any important data on your drive.
Hello JDELA22,
We were reviewing your community post and we would like to know if you need further assistance related to the Intel® Data Migration Software or if we can close this community thread.
Josh B.
Hello JDELA22,
We will like to know if the troubleshooting steps we shared with you helped you to solve the issue you reported with the Intel® Data Migration Software or if further assistance is required.
Josh B.
