cancel
Showing results for
Search instead for
Did you mean:
Boot time of 750(U.2 type)
WWENG2
New Contributor
As known, because of the PCI initialization time.
Intel 750 SSD (PCI-E type) has a long boot time
/thread/75676?q=intel 750 boot https://communities.intel.com/thread/75676?q=intel%20750%20boot
Therefore, the same problem also occurs in U.2 type?
1 ACCEPTED SOLUTION
Esteemed Contributor III
SmallBee,
We would like to let you know that the Add-in-card and the SFF-8639 are both PCIe 3.0 x4 drives, the initialization process is similar for both form factors. We recommend to have the drives updated with the latest firmware update available.
2 REPLIES 2
SmallBee,
SmallBee,
We would like to know if the information provided worked for you or if you still require assistance.
We will be waiting for your response.
