Community
cancel
Showing results for
Search instead for
Did you mean:
JJaso10
Bootable raid 0 over dual u.2 ports on the Gigabyte X99 Designare EX.
Jump to solution
Heya,
so, I'm working on a new build with the X99 Designare and a 6850k. So far I'm loving it. But I'm having a lot of trouble finding relevant information about setting up a raid array between the two u.2 ports.
I have a pair of 5TB Toshiba conventional SATA drives which the BIOS immediately recognized and allowed me to setup in raid0 using the lovely EZ RAID setup.
I also have two Intel 750's of the 1.2TB, 2.5 inch, u.2 variety which the BIOS recognises without issue, but which i can't seem to find a way to RAID them in the BIOS. Neither of the two ways to setup a RAID via this BIOS even show them as an option. But I believe I need to get it done via BIOS because I want them in bootable RAID0 so i can install Windows 10 and use them as my c: drive.
Any suggestions?
Thanks for your time.
PS: apologies for the text color flip. It's not intentional. I'm posting from a tablet which is not cooperating with this forum's text editor. =(
Message was edited by: Jason Organist
Community Manager
Hello Je-Tze,
We understand you would like to setup a RAID 0 in your system using the U.2 version of our Intel® SSD 750 Series.
We would like to let you know that in regards the Intel® X99 chipset, this does not allow RAID configuration with NVMe* drives, this because the drives are mapped to the CPU.
You may want to double check with http://www.gigabyte.eu/support-downloads/technical-support.aspx Gigabyte about this, since it may vary between motherboards.
Now, for you to do a RAID with NVMe* SSDs, you need the drives to be mapped to the chipset or to a storage controller that supports the feature.
Let us know if you need further information.
NC
Community Manager
Hello Je-Tze,
NC
JJaso10
Oh. =(
Oh well. Thanks for for help.
I was really careful in researching this build before I took the plunge but that is something I totally missed.
Never in my wildest dreams did I imagine that the extra PCIE lanes from the CPU with socket 2011-3/x99 would turn out to be a bad thing.
Damn. Live and learn.
JJaso10
I still have a support ticket in at Gigabyte, so maybe it'll turn out they have some kind of work-around, but it's not looking good.
Thanks again to anyone who spent time trying to figure this out.
Community Manager
Hi Je-Tze,
Thanks for the reply. We normally suggest to verify with the OEM of the motherboard. In your case, you did well opening a ticket with Gigabyte* already, maybe, as you mentioned, they could provide a work around or let you know what options do they have.
NC
