Community
cancel
Showing results for
Search instead for
Did you mean:
ANiel2
Brand new 525 SSD (120GB) stops responding on write
Hi all,
I am just setting up a brand new 525-series SSD (SSDMCEAC12) and as soon as I try to write more than a few MB of data to it it stops responding. I can't even use smartctl to get any details out of the drive, and if I reset the PC it locks up at the BIOS logo (motherboard is an Intel DH87MC.)
If I power off the board for a few minutes then everything seems fine until I write more than a few MB to the SSD and then it stops responding again. Am I doing something wrong? I'm just booting Linux off a USB stick and copying files onto the SSD over the network (so that I can then boot off the SSD instead.) The SSD is not warm at all so it's not a temperature issue. Before it locks up smartctl reports a normal temperature (33 degrees.)
Here are some of the kernel messages I get when things break:
Sep 07 16:07:52 archiso kernel: ata6.00: exception Emask 0x0 SAct 0xfffffff SErr 0x0 action 0x6 frozen Sep 07 16:07:52 archiso kernel: ata6.00: failed command: READ FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [135B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } Sep 07 16:07:52 archiso kernel: ata6.00: failed command: WRITE FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [138B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } Sep 07 16:07:52 archiso kernel: ata6.00: failed command: WRITE FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [138B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } Sep 07 16:07:52 archiso kernel: ata6.00: failed command: WRITE FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [138B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } Sep 07 16:07:52 archiso kernel: ata6.00: failed command: WRITE FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [138B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } Sep 07 16:07:52 archiso kernel: ata6.00: failed command: WRITE FPDMA QUEUED Sep 07 16:07:52 archiso kernel: [138B blob data] Sep 07 16:07:52 archiso kernel: ata6.00: status: { DRDY } ... Sep 07 16:07:52 archiso kernel: ata6: hard resetting link Sep 07 16:07:58 archiso kernel: ata6: link is slow to respond, please be patient (ready=0) Sep 07 16:08:02 archiso kernel: ata6: COMRESET failed (errno=-16) Sep 07 16:08:02 archiso kernel: ata6: hard resetting link Sep 07 16:08:08 archiso kernel: ata6: link is slow to respond, please be patient (ready=0) Sep 07 16:08:12 archiso kernel: ata6: COMRESET failed (errno=-16) Sep 07 16:08:12 archiso kernel: ata6: hard resetting link Sep 07 16:08:18 archiso kernel: ata6: link is slow to respond, please be patient (ready=0) ... Sep 07 16:08:47 archiso kernel: ata6: COMRESET failed (errno=-16) Sep 07 16:08:47 archiso kernel: ata6: limiting SATA link speed to 3.0 Gbps Sep 07 16:08:47 archiso kernel: ata6: hard resetting link Sep 07 16:08:52 archiso kernel: ata6: COMRESET failed (errno=-16) Sep 07 16:08:52 archiso kernel: ata6: reset failed, giving up Sep 07 16:08:52 archiso kernel: ata6.00: disabled Sep 07 16:08:52 archiso kernel: ata6.00: device reported invalid CHS sector 0 Sep 07 16:08:52 archiso kernel: ata6.00: device reported invalid CHS sector 0
Tags (1)
Jose_H_Intel1
Malvineous, you may want to try updating the BIOS. In case it does not help, I wonder if you have the possibility of testing the Intel® SSD 525 in a different computer.
Please let us know about the results.
ANiel2
Thanks for your reply. I tried updating the BIOS (v43 to v47) but it didn't make a difference, which is probably because Linux accesses the hardware directly.
Unfortunately I can't test the SSD in a different computer as it's an mSATA device and the DH87MC motherboard is the only device I have with an mSATA slot. I do however have another two 3.5" hard disks attached to the board through the same onboard SATA controller and they work normally.
Are there any known problems with this series of SSD that causes them to lock up and stop responding to host commands?
Jose_H_Intel1
We are currently researching this issue.
ANiel2
Is there any news on this issue? After working through diagnostics with Intel support, and having their diagnostic programs report the drive as not responding after the first write, I returned the SSD via the standard warranty replacement procedure.
The replacement SSD arrived yesterday and I just tried to set it up and the replacement one also freezes as soon as I try to write to it! In the meantime I bought an mSATA to normal SATA adapter, so this time I am trying the SSD in a completely different PC, yet it behaves exactly the same way!
I have to say I'm pretty annoyed - two out of two devices failing, a 100% failure rate - is pretty poor by any standards. I expected much better from Intel. Do these devices actually get tested before they leave the factory?? It appears not:
[1075679.229162] ata8.00: exception Emask 0x0 SAct 0x7000ffff SErr 0x0 action 0x6 frozen [1075679.229170] ata8.00: failed command: WRITE FPDMA QUEUED [1075679.229178] ata8.00: cmd 61/00:00:00:30:09/04:00:00:00:00/40 tag 0 ncq 524288 out res 40/00:01:00:00:00/00:00:00:00:00/e0 Emask 0x4 (timeout) [1075679.229182] ata8.00: status: { DRDY } [1075679.229185] ata8.00: failed command: WRITE FPDMA QUEUED [1075679.229192] ata8.00: cmd 61/00:08:00:38:09/04:00:00:00:00/40 tag 1 ncq 524288 out res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [1075679.229196] ata8.00: status: { DRDY } [1075679.229199] ata8.00: failed command: WRITE FPDMA QUEUED [1075679.229205] ata8.00: cmd 61/00:10:00:3c:09/04:00:00:00:00/40 tag 2 ncq 524288 out res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [1075679.229209] ata8.00: status: { DRDY } [1075679.229212] ata8.00: failed command: WRITE FPDMA QUEUED [1075679.229218] ata8.00: cmd 61/00:18:00:40:09/04:00:00:00:00/40 tag 3 ncq 524288 out res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [1075679.229222] ata8.00: status: { DRDY } [1075679.229225] ata8.00: failed command: WRITE FPDMA QUEUED [1075679.229231] ata8.00: cmd 61/00:20:00:44:09/04:00:00:00:00/40 tag 4 ncq 524288 out res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) [1075679.229235] ata8.00: status: { DRDY } ... [1075679.229376] ata8: hard resetting link [1075689.232475] ata8: softreset failed (1st FIS failed) [1075689.232482] ata8: hard resetting link [1075699.232459] ata8: softreset failed (1st FIS failed) [1075699.232467] ata8: hard resetting link [1075734.232447] ata8: softreset failed (1st FIS failed) [1075734.232456] ata8: limiting SATA link speed to 1.5 Gbps [1075734.232460] ata8: hard resetting link [1075739.409117] ata8: softreset failed (device not ready) [1075739.409124] ata8: reset failed, giving up [1075739.409128] ata8.00: disabled [1075739.409136] ata8.00: device reported invalid CHS sector 0 [1075739.409140] ata8.00: device reported invalid CHS sector 0 [1075739.409145] ata8.00: device reported invalid CHS sector 0 [1075739.409149] ata8.00: device reported invalid CHS sector 0 [1075739.409152] ata8.00: device reported invalid CHS sector 0 [1075739.409156] ata8.00: device reported invalid CHS sector 0 [1075739.409159] ata8.00: device reported invalid CHS sector 0 [1075739.409164] ata8.00: device reported invalid CHS sector 0 [1075739.409168] ata8.00: device reported invalid CHS sector 0 ... [1075739.409284] ata8: EH complete [1075739.409325] sd 7:0:0:0: [sdi] Unhandled error code [1075739.409328] sd 7:0:0:0: [sdi] Unhandled error code [1075739.409331] sd 7:0:0:0: [sdi] [1075739.409334] Result: hostbyte=0x04 driverbyte=0x00 [1075739.409336] sd 7:0:0:0: [sdi] CDB: [1075739.409345] sd 7:0:0:0: [sdi] [1075739.409348] Result: hostbyte=0x04 driverbyte=0x00 [1075739.409350] sd 7:0:0:0: [sdi] CDB: [1075739.409339] cdb[0]=0x2a: 2a [1075739.409353] cdb[0]=0x2a [1075739.409355] : [1075739.409357] 2a [1075739.409358] 00 [1075739.409360] 00 [1075739.409361] 09 [1075739.409363] 34 [1075739.409364] 00 [1075739.409365] 00 [1075739.409367] 04 [1075739.409368] 00 [1075739.409369] 00 [1075739.409373] end_request: I/O error, dev sdi, sector 603136 [1075739.409378] EXT4-fs warning (device sdi3): ext4_end_bio:332: I/O error writing to inode 1442316 (offset 0 size 8388608 starting block 75520) ... [1075739.411155] Buffer I/O error on device sdi3, logical block 0 [1075739.411156] lost page write due to I/O error on sdi3 [1075739.411174] EXT4-fs error (device sdi3): ext4_journal_check_start:56: Detected aborted journal [1075739.411177] EXT4-fs (sdi3): Remounting filesystem read-only [1075739.411179] EXT4-fs (sdi3): previous I/O error to superblock detected [1075739.411192] sd 7:0:0:0: [sdi] Unhandled error code [1075739.411194] sd 7:0:0:0: [sdi] [1075739.411196] Result: hostbyte=0x04 driverbyte=0x00 [1075739.411198] sd 7:0:0:0: [sdi] CDB: [1075739.411199] cdb[0]=0x2a: 2a 00 00 04 08 00 00 00 08 00 [1075739.411206] Buffer I/O error on device sdi3, logical block 0 [1075739.411207] lost page write due to I/O error on sdi3
Jose_H_Intel1
Hi Malvineous,
We are still working on diagnosing what is causing this issue (and a few others) with the 525 SSD and the DH87MC motherboard. We're sorry it's taking so long. We will update this thread when we get new information from out engineering teams.
ANiel2
Thanks Joe. What other issues are you experiencing with the 525 series? I'd like to know what to look out for.
KenF_Intel
Malvineous,
What Linux distro are you working with? Have you tried any other OS's?
ANiel2
I've tried it under Arch Linux, with kernel 3.11.1, and under FreeDOS with the hdat2 utility, as requested by Intel support. Neither OS was able to write anything, not even a partition table. (Under Linux this seemed to work due to the disk cache, but running 'sync' killed the SSD. Replugging it brought it back, minus the partition table.) Under FreeDOS, the hdat2 utility reported timeout errors when attempting to write to sectors - no write was successful. After one run, hdat2 could no longer detect the SSD until it was power cycled.
hdat2 did not support the mSATA socket (it only supports the first few SATA devices and mSATA appears as device 6) so I had to use BIOS support to access the device. So I guess the OS in this case is the DH87MC board's real mode BIOS.
CGree2
Malvineous & kford-Intel,
I just posted my problem here:
/thread/45811 https://communities.intel.com/thread/45811
Very similar - if not the same - problem.
KenF_Intel
Hi Malvineous,
The only similar report we have is a report of the 240GB version not being recognized by the DH87MC. Our engineers have recreated that problem and are investigating the possible cause.
The interesting thing about that other report is that it only affects the 240GB model of the 525 SSD.
JTso
Similar problem with Intel 525 180GB on DH87MC:
/message/210541# 210541 https://communities.intel.com/message/210541# 210541
Any updates?
ANiel2
Just to provide an update on this, I am told that the problem seems to be with the power supplied to the mSATA port on the DH87MC motherboard. Apparently the SSD needs power at the higher end of the spec, but the board delivers power at the lower end. So while both devices are in spec, being at opposite extremes there is some resulting unreliability.
Intel have offered to refund my purchase price for the motherboard which is very nice of them, but I'd like to keep the board so I've asked them whether they can refund the SSD instead. I would like to get another device that isn't mSATA and see if I can squash it into my tiny case somewhere so I can keep the Intel motherboard, which was the whole point of this upgrade (wanted Intel onboard video for the open source Linux drivers.)
I would also like to say I wish I could get this level of support from other IT companies! It's nice to deal with a company that really does stand behind their products.
MMISS53
I doubt it's actually the motherboard that it the problem; I just had one of these drives fail with the same error. I have two of them- one works fine the other just died and I lost a ton of data. Ironically, the drive died when I was backing up my work.
Not happy.
ANiel2
Yes I plugged mine into a SATA 2.5" adapter and it didn't work there either. I think the drives just require above average power availability (perhaps at the upper limit of the spec) which they can't get.
Community Manager
I just bought an Intel 525 240GB and attached it to a machine and I just encountered the same issue. The motherboard is a GIGABYTE M4HM87P-00 with BIOS F2 (latest available AFAIK). Is there a firmware issue or something?
[ 2140.580025] ata5.00: exception Emask 0x10 SAct 0x7fffffff SErr 0x4890000 action 0xe frozen
[ 2140.580056] ata5.00: irq_stat 0x08400040, interface fatal error, connection status changed
[ 2140.580082] ata5: SError: { PHYRdyChg 10B8B LinkSeq DevExch }
[ 2140.580100] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580118] ata5.00: cmd 61/00:00:00:10:7d/04:00:01:00:00/40 tag 0 ncq 524288 out
res 40/00:28:00:a8:7c/00:00:01:00:00/40 Emask 0x10 (ATA bus error)
[ 2140.580164] ata5.00: status: { DRDY }
[ 2140.580176] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580193] ata5.00: cmd 61/00:08:00:14:7d/04:00:01:00:00/40 tag 1 ncq 524288 out
[ 2140.580238] ata5.00: status: { DRDY }
[ 2140.580250] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580267] ata5.00: cmd 61/00:10:00:18:7d/04:00:01:00:00/40 tag 2 ncq 524288 out
[ 2140.580311] ata5.00: status: { DRDY }
[ 2140.580323] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580340] ata5.00: cmd 61/00:18:00:a0:7c/04:00:01:00:00/40 tag 3 ncq 524288 out
[ 2140.580384] ata5.00: status: { DRDY }
[ 2140.580396] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580413] ata5.00: cmd 61/00:20:00:a4:7c/04:00:01:00:00/40 tag 4 ncq 524288 out
[ 2140.580457] ata5.00: status: { DRDY }
[ 2140.580469] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580486] ata5.00: cmd 61/00:28:00:a8:7c/04:00:01:00:00/40 tag 5 ncq 524288 out
[ 2140.580531] ata5.00: status: { DRDY }
[ 2140.580543] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580560] ata5.00: cmd 61/00:30:00:ac:7c/04:00:01:00:00/40 tag 6 ncq 524288 out
[ 2140.580604] ata5.00: status: { DRDY }
[ 2140.580616] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580633] ata5.00: cmd 61/00:38:00:b0:7c/04:00:01:00:00/40 tag 7 ncq 524288 out
[ 2140.580678] ata5.00: status: { DRDY }
[ 2140.580689] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580706] ata5.00: cmd 61/00:40:00:b4:7c/04:00:01:00:00/40 tag 8 ncq 524288 out
[ 2140.580751] ata5.00: status: { DRDY }
[ 2140.580762] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580780] ata5.00: cmd 61/00:48:00:b8:7c/04:00:01:00:00/40 tag 9 ncq 524288 out
[ 2140.580824] ata5.00: status: { DRDY }
[ 2140.580836] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580854] ata5.00: cmd 61/00:50:00:bc:7c/04:00:01:00:00/40 tag 10 ncq 524288 out
[ 2140.580898] ata5.00: status: { DRDY }
[ 2140.580910] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.580927] ata5.00: cmd 61/00:58:00:c0:7c/04:00:01:00:00/40 tag 11 ncq 524288 out
[ 2140.580972] ata5.00: status: { DRDY }
[ 2140.580983] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.581000] ata5.00: cmd 61/00:60:00:c4:7c/04:00:01:00:00/40 tag 12 ncq 524288 out
[ 2140.581045] ata5.00: status: { DRDY }
[ 2140.581056] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.581074] ata5.00: cmd 61/00:68:00:c8:7c/04:00:01:00:00/40 tag 13 ncq 524288 out
[ 2140.581118] ata5.00: status: { DRDY }
[ 2140.581130] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.581148] ata5.00: cmd 61/00:70:00:cc:7c/04:00:01:00:00/40 tag 14 ncq 524288 out
[ 2140.581193] ata5.00: status: { DRDY }
[ 2140.581204] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.581221] ata5.00: cmd 61/00:78:00:d0:7c/04:00:01:00:00/40 tag 15 ncq 524288 out
[ 2140.581266] ata5.00: status: { DRDY }
[ 2140.581278] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.581295] ata5.00: cmd 61/00:80:00:d4:7c/04:00:01:00:00/40 tag 16 ncq 524288 out
[ 2140.581339] ata5.00: status: { DRDY }
[ 2140.581351] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.582430] ata5.00: cmd 61/00:88:00:d8:7c/04:00:01:00:00/40 tag 17 ncq 524288 out
[ 2140.584674] ata5.00: status: { DRDY }
[ 2140.585760] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.586843] ata5.00: cmd 61/00:90:00:dc:7c/04:00:01:00:00/40 tag 18 ncq 524288 out
[ 2140.588985] ata5.00: status: { DRDY }
[ 2140.590050] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.591120] ata5.00: cmd 61/00:98:00:e0:7c/04:00:01:00:00/40 tag 19 ncq 524288 out
[ 2140.593277] ata5.00: status: { DRDY }
[ 2140.594338] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.595402] ata5.00: cmd 61/00:a0:00:e4:7c/04:00:01:00:00/40 tag 20 ncq 524288 out
[ 2140.597536] ata5.00: status: { DRDY }
[ 2140.598598] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.599664] ata5.00: cmd 61/00:a8:00:e8:7c/04:00:01:00:00/40 tag 21 ncq 524288 out
[ 2140.601800] ata5.00: status: { DRDY }
[ 2140.602882] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.603973] ata5.00: cmd 61/00:b0:00:ec:7c/04:00:01:00:00/40 tag 22 ncq 524288 out
[ 2140.606644] ata5.00: status: { DRDY }
[ 2140.607973] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.609304] ata5.00: cmd 61/00:b8:00:f0:7c/04:00:01:00:00/40 tag 23 ncq 524288 out
[ 2140.611527] ata5.00: status: { DRDY }
[ 2140.612599] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.613691] ata5.00: cmd 61/00:c0:00:f4:7c/04:00:01:00:00/40 tag 24 ncq 524288 out
[ 2140.615841] ata5.00: status: { DRDY }
[ 2140.616909] ata5.00: failed command: WRITE FPDMA QUEUED
[ 2140.617982] ata5.00: cmd 61/00:c8:00:f8:7c/04:00:01:00:00/40 tag 25 ncq 524288 out
Community Manager
Also, I tried doing a long SMART test via 'smartctl -t long /dev/sdb', and eventually this happened and the device dropped off the SATA bus:
[ 407.025624] ata5: exception Emask 0x50 SAct 0x0 SErr 0x4090800 action 0xe frozen
[ 407.025652] ata5: irq_stat 0x00400040, connection status changed
[ 407.025672] ata5: SError: { HostInt PHYRdyChg 10B8B DevExch }
[ 407.025693] ata5: hard resetting link
[ 407.770332] ata5: SATA link down (SStatus 0 SControl 300)
[ 412.774313] ata5: hard resetting link
[ 413.124594] ata5: SATA link down (SStatus 0 SControl 300)
[ 413.124600] ata5: limiting SATA link speed to 1.5 Gbps
[ 418.128590] ata5: hard resetting link
[ 418.478858] ata5: SATA link down (SStatus 0 SControl 310)
[ 418.478865] ata5.00: disabled
[ 418.478884] ata5: EH complete
[ 418.478889] ata5.00: detaching (SCSI 4:0:0:0)
[ 418.479096] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[ 418.479111] sd 4:0:0:0: [sdb]
[ 418.479113] Result: hostbyte=0x04 driverbyte=0x00
[ 418.479129] sd 4:0:0:0: [sdb] Stopping disk
[ 418.479133] sd 4:0:0:0: [sdb] START_STOP FAILED
[ 418.479149] sd 4:0:0:0: [sdb]
[ 418.479150] Result: hostbyte=0x04 driverbyte=0x00
ANiel2
Don't take this the wrong way, but maybe you should read the thread first before posting - you would have already found your answer if you did!
Community Manager
I haven't seen an answer, only an unconfirmed theory that it's not drawing enough power from the motherboard.
ANiel2
It's not a theory, it's what Intel engineering believe the problem is. So it looks like your only options are to somehow try getting a bit more power to the board (assuming the 3.3V rail on the mSATA slot comes from the PSU and you have one with an adjustable 3.3V rail) or to return the SSD and try another one.
