Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Bug intel® Memory and Storage Tool
A_V
Dear community, I immediately apologize for my English. I have in the system 2 Intel® SSD 545s Series. At 512GB Windows 10 PRO - x64 system is located, and there is a swap file on 128GB. After upgrading to 20H2 on the system drive Intel's optimization stopped working Intel® Solid State Drive Toolbox, before it could start issuing an error, at the same time on the disk with a pumping normally works. After intel® Memory and Storage Tool (GUI) the situation does not change. The Intel® Driver and Support Assistant app speaks to the relevance of drivers. I wish I could, understand, given that the situation is not one of them, it is a Windows or Intel bug® Memory and Storage Tool (GUI), which this will have an impact on the drive and whether there will be a fix.
BrusC_Intel
Hello, @A_V.
Good day, and thank you for contacting Intel Community Support.
I received your thread regarding the optimization error, I will be glad to assist you.
The error encountered while trying to use the optimizer is still being investigated, but there is another option for you if using this feature is required as it can be executed directly from the OS, please review the following article:
https://www.intel.com/content/www/us/en/support/articles/000057205/memory-and-storage.html
If there is anything else, please let me know.
Bruce C.
BrusC_Intel
Hello, @A_V.
Bruce C.
A_V
Hello Bruce ! Thank you for taking the time to answer me. I watched this temporary solution. I hope Intel engineers will find a solution soon.
With respect A_V.
