Community
cancel
Showing results for
Search instead for
Did you mean:
SFisk
Can I use a Intel SSD 600P drive (SSDPEKKW512G7X1) on a Intel® H170 Chipset (DH82H170)??
Hello.
Does anyone know about this SSD hard drive can run on this motherboard.?
Intel SSD 600P drive (SSDPEKKW512G7X1) on a Intel® H170 Chipset (DH82H170).
Community Manager
Hello Fisker,
Thank you for your question.
There are many compatible motherboards using the Intel® H170 Chipset. However we cannot guarantee compatibility based on the chipset only.
- http://www.intel.com/content/www/us/en/support/solid-state-drives/consumer-ssds/000022677.html Motherboards Supporting the Intel® SSD 600p/Pro 6000p/E 6000p Series.
- http://www.intel.com/content/www/us/en/support/solid-state-drives/000022378.html Frequently Asked Questions for Intel® SSD 600p/Pro 6000p Series.
The main requirement for the http://www.intel.com/content/www/us/en/solid-state-drives/solid-state-drives-600p-series.html Intel® SSD 600p Series is a storage M.2 slot, supporting PCIe* NVMe* generation 3.0 by 4 lanes. In this case we would like to recommend for you to confirm compatibility with the motherboard manufacturer.
Please let us know if you have any additional questions.
Carlos A.
Community Manager
The Intel H170 includes DMI3 support, which means it will support the full bandwidth requirements of an Intel 600p. The H170 chipset itself won't be a limiting factor on a mother board when using a 600p.
