cancel
Showing results for
Search instead for
Did you mean:
Can Intel DC S4500 be power up with +5V only.
KGong1
New Contributor
Can anyone help to advice whether Intel DC S4500 can power up with +5V only?
I was inform it is able to support but i could find any infomation from Intel DC S4500 specification.
thanks
KH
4 REPLIES 4
Esteemed Contributor III
Hi Porthelp,
We understand your concern regarding that if the Intel® SSD DC S4500 Series can be power up with +5V only.We would like to inform you that the SSD can be powe up with 5V or 5V+12V SATA Supply Rail*. If both 12V and 5V power supplies are present, defaults to 5V+ 12V power supplies. Does not support 12 volt only.Please let us know if there is something else we can assist you with. Regards, Junior M.
Hi Porthelp,
We would like to know if you read our previous post and if you have any other questions. We'll be waiting for your response.Regards, Junior M.
KGong1
New Contributor
Hi Junior M.,
Thanks for yr reply. I have 1 unit not able to power up by +5v only but when connect with +5 and +12V, it is able to power up.
Will return for RMA.
Porthelp
Hi Porthelp,
Thanks for the update. We recommend you to contact your local support team for the RMA process. If you have further questions then feel free to contact us again. Regards,Junior M.
