Community
cancel
Showing results for
Search instead for
Did you mean:
thawk3
Can i use a nvme drive in a optiplex 780 with an adapter card to boot with?
Jump to solution
LeonWaksman
So, the NVMe driver is included in Windows 10, but you should asked Dell about the capability to recognize NVMe drive.
Leon
LeonWaksman
First you should check in Dell, if the NVMe drive is supported by this computer. As far I know, only SATA II (even not SATA III) is supported. So, probably the NVMe drive will not be even recognized, forget about booting. You didn't mentioned what is the O.S. you have installed on this PC?
Leon
thawk3
Windows 10 64
LeonWaksman
Leon
n_scott_pearson
Super User Retired Employee
Leon is correct. First of all, if the BIOS does not have enabled UEFI support, you cannot use NVMe drives. Secondly, unless this PCIe NVMe adapter provides a UEFI OpROM to support booting, you will not be able to boot from the NVMe drive nor will you be able to use it as your system drive.
