Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Can't install XP on X25-V
just bought a X25-V, and began installing Windows XP. Well, after the first boot during install, an error message appears (can't read it because it disappears fast) and the computer reboots.
How can I solve this?
Community Manager
Two more problems in the last few hours:
Managed to install Vista on the disk, it went fine. Then I ran Windows update. It started, installed about 50% of the updates, then the computer started rebooting. No matter how many times I tried updating Windows, it always rebooted after a few minutes.
Then, I thought of updating the firmware. I always got the "No Intel SSD installed" error message. And yes, it is installed.
Enabled AHCI in the BIOS, tried it all over again, and no joy....
So, any help on this before I return the SSD?
Community Manager
Nobody? Am I the first to run into these problems?
RGiff
Honored Contributor I
Look at Microsoft article # KB/922979. It will tell you how to install AHCI , after OS is installed, this does involve some registry editing , So if you do this read it 3 times do it right once.
Community Manager
Hey JonL,
I'm an Intel employee and on your behalf, we ran a few tests. Have you tried entering your BIOS during the XP install to boot in ATA mode? If you'd like to install the latest RST drivers with Windows XP, you'll need to use what's called the "F6" method. You can read more about it here:
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2101&DwnldID=18860&lang=eng&iid=dc_rss http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2101&DwnldID=18860&lang=eng&iid=dc_rss
Don't hesitate if you have more questions!!!
Scott
Community Manager
Tried the F6 recommendation; however, a number of SATA-RAID options are included and we have not been able to successfully select the appropriate driver for the BIOS in the HP-Compaq computer. The HP Product Number is NV557UT# ABA. Any additional feedback would be appreciated.
