Community
cancel
Showing results for
Search instead for
Did you mean:
DPete12
Can't run SSD optimizer on 750 series 400GB?
Jump to solution
Maybe a simple question... I downloaded the SSD Toolbox, updated the SSD Firmware (now up to date) but the can't 'Run' the SSD Optimizer (greyed out) on my 750 Series 400GB?
(The drive is running fine but just want to ensure the best life for the SSD)
System Info from Toolbox
Win 10.0.14393
ASUS
Processor: Intel(R) Core(TM) i7-6900K CPU @ 3.2GHz
(Hardware ID - SCSI\DiskNVMe____INTEL_SSDPEDMW4001F0)
Standard SATA AHCI Controller
Version 10.0.14393.206
Stardard NVM Express Controller
Microsoft Storage Spaces Controller
Version 10.0.14393.351
Tags (1)
Community Manager
Hello DSalt,
We understand that you would like to manually run the SSD optimizer (trim) from the Intel® SSD Toolbox, but the option is greyed out.
For our Toolbox to be able to send the TRIM command to your SSD, you will first need to install the latest Intel® NVMe* Driver. Installing this driver will help your SSD work at it's best much more than running the optimizer will. In some cases, you may also need to update your BIOS.
- https://downloadcenter.intel.com/download/26451 Intel® SSD NVMe* Drivers.
Windows* 10 was built with SSDs in mind, so your operating system is by default already optimizing your drive, usually on a scheduled weekly basis. Manually running the optimizer is usually not recommended, as it will put unnecessary wear on your drive.
For more information on SSD Optimization and how to check if TRIM is enabled, we can recommended the following article:
- https://www.howtogeek.com/256859/dont-waste-time-optimizing-your-ssd-windows-knows-what-its-doing https://www.howtogeek.com/256859/dont-waste-time-optimizing-your-ssd-windows-knows-what-its-doing/
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
If you have any further questions or doubts, please let us know.
Carlos A.
Community Manager
Hello DSalt,
Carlos A.
Community Manager
Hello DSalt,
We're following up on your thread since we have not heard back from you.
Did our driver help resolve your issue? Please let us know if you have any further questions.
Carlos A.
DPete12
Thank you for the reply, that helped. I updated the driver as you mentioned and also learnt a lot from that link.
It seems that basically Windows does a lot of the SSD optimisation automatically which is great!
Thanks again.
Community Manager
Hello DSalt,
Solid state drives have come a long way in a short time, I'm glad you found that article as informative as we hoped.
In case you need further any assistance, just let us know. We're always glad to help.
Carlos A.
