Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Can't use my SSD drive as cache
Jump to solution
Hi there,
I bought a new Lenovo u410 and installed windows 8 pro on it.
I have an HDD 750gb primary drive and a 32GB SSD which I want to use him as a cache drive.
My BIOS configuration is set on RAID, I can see the SSD drive in the Intel Rapid Storage GUI in windows,
But the accelerate button is not thereץ
What can I do??
Yoav
Community Manager
I've run into a similar problem.
Try this:
Make sure you don't have any data that you want on your SSD cause it's going to get wiped.
hit windows-key+R
type in DISKPART
(or just open CMD and type DISKPART at command line)
Type LIST DISK
Look at the output and select your SSD like so (if it's disk 1)
SELECT DISK 1
Then type:
CLEAR
and
EXIT
Restart the ISRT manager and you should now hopefully see the accelerate tab.
Community Manager
Anyone?
Community Manager
Does your HDD have a recovery volume on it? That is common with laptops. If so, the recovery volume does not allow acceleration/caching.
If you run the IRST GUI, and click on Help, you'll find an entry about Accelerating the system, which may help you.
Community Manager
Hey,
My HDD had a recovery partition. I deleted it and reinstall the Raid storage driver again, but......
The acceleration button is still missing...
Community Manager
I was able to accelerate my notebook hdd after deleting/toggling a second NTFS-partition which wasn't a recovery partition.
Community Manager
But i need my second hdd partition....
Is there any other option??
Community Manager
I would boot with a Linux CD or DVD to toggle the second NTFS partition from 7 (NTFS) to 83 (Linux), reboot and check whether the acceleration is working then or not. After the test you can re-toggle it back to 7. That's the way I did it.
Community Manager
Try this:
hit windows-key+R
type in DISKPART
Type LIST DISK
SELECT DISK 1
Then type:
CLEAR
and
EXIT
Community Manager
It worked!!!
It's clean and not clear, but you're great...
