Community
cancel
Showing results for
Search instead for
Did you mean:
BKOAY
Cannot check warranty status for SSD
The check warranty function for SSD seem like doesn't works already. The search results doesn't show the serial number i have entered, and return negative result. Besides, i had tried to enter both the ISN and Serial No in order to check but the result is same.
itpnadminintel_admin
Tags (1)
Community Manager
Please try again and enter both the ISN and SA#
BKOAY
I had tried for many times already. All possible action also tested~ Please check the function whether still working? Since the output doesn't show the corresponding value..
ASouz7
BC_K,
Could you please try this. Here are the results I got upon trying the steps below.
Once you enter with those pieces of information click on Search. Let us know if it worked for you.
BKOAY
By using this, i can retrieve the warranty info~ So, i guess the search function for SSD got problem.
