Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
Clone OS drive - Does Intel Data Migration work with 800p NVME SSD?
TBui7
Hello, I just purchased the 58gb 800p NVME Optane module that I am using just as a drive. I have it mounted as E: in my system. I want to clone my current OS and its data from the existing SSD to the new 800p NVME drive. The FAQ of the Intel Data Migration application says that it does not support NVME? I dont why understand why the application wouldnt just recognize the 800p NVME as another drive. Why does it matter if its SATA or NVME? Can someone please confirm? If NVME is indeed not supported, can I please get a recommendation for software that I can use to migrate my OS to the Optane?
Hi tboooe,
Thank you for contacting our support community. We understand that you want to clone your OS to the Intel® Optane™ SSD 800P Series.
We would like to let you know that Intel® Data Migration Software does not support NVMe* cloning process, It only supports SATA to SATA cloning process. However, there are some 3rd party tools that may be able to complete the task such as http://clonezilla.org/ Clonezilla* or paid versions of other 3rd party tools such as https://www.acronis.com/en-us/ Acronis* or https://www.easeus.com/backup-software/tb-home.html%3Fgclid%3DCjwKCAiA4vbSBRBNEiwAMorER-eHoPHpGWXmZxLGB1_zfamFfzNmv9qRHDukqiU36qaA7Zn7fxehOBoCvWwQAvD_BwE Easeus* Todo Backup.
You may want to check with the software vendor before purchasing in order to verify if they will be able to complete the task.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Junior M.
Ili2
a few days ago, i tried a third party tool called AOMEI Backupper, which can https://www.ubackup.com/windows-10/clone-windows-10-to-nvme-4348i.html clone SSD to nvme SSD successfully and boot from my computer. if you do not find any useful software, you can try this software.
TBui7
Thank you so much for the recommendation. Which version of Backupper did you use? I see 4 different versions on their site:
Free, Professional, Server, Technician.
Hi tboooe,
You may want to reach out to the software vendor to find out which of the options better fits your needs. Here is the https://www.backup-utility.com/contact-us.html contact information.
Junior M.
