Community
cancel
Showing results for
Search instead for
Did you mean:
GMin
Compatibility question about 750 SSD with Dell T5600
Hi all,
I have a question about compatibility Intel 750 SSD with Dell T5600 Workstation.
My T5600 is using x79 chipset with SandyBridge Xeon, and it is not support NVME.
I don`t want to use it bootable device but only using storage perpose. (Hyper-V Storage)
T5600`s Technical Sheet : http://www.dell.com/support/article/us/en/04/sln290309/the-hardware-specifications-for-the-precision... The hardware specifications for the Precision T5600 Desktop Workstation | Dell US
How performance will be this situation?
Just half?
Thank you
Tags (1)
Community Manager
Hello dydrlek,
For the Intel® SSD 750 Series to be detected, even as a secondary storage device, your PCIe port must support NVMe*.
Based on these hardware specifications, the Intel® SSD 750 Series is not compatible with your workstation. It's unlikely that the drive will be detected at all.
However, there is always the chance that these specifications are not complete. For a second opinion, we can recommend checking with your computer manufacturer (Dell*).
- https://www.intel.com/content/www/us/en/support/memory-and-storage/enthusiast-ssds/000005797.html Before You Buy an Intel® SSD 750 Series.
We hope this information helps.
Carlos A.
GMin
Hi Carlos,
Thank you for let me know important information.
Thank you
Community Manager
Hello Dydrlek,
You're welcome. Do let us know if there is anything else we can help you with.
Carlos A.
