Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Confirm proper Trim? Format or not?
Now that my firmware is completed successfully and my benchmark scores are still fabulous, how do I MAKE SURE that my drive is running as it should? By this I mean with TRIM enabled in Win7 64-bit? What about SMART status?
Also, should I continue using my SSD with my current windows setup (same as stock drive WITHOUT new firmware) or would it be best to format and do a wipe and reinstall everything on the drive now that TRIM is enabled? Would this increase performance? Longevity? Or is not necessary?
Community Manager
CrystalDiskInfo shows TRIM under SUPPORTED FEATURES, but does this mean that TRIM is active????
