Intel® Optane™ Memory
1345 Discussions
Consumer m.2 optane double sided, x4 lane
https://www.anandtech.com/show/12562/intel-previews-optane-enterprise-m2-ssd Intel Previews Optane Enterprise M.2 SSD - so intel made p4801x, m.2 22110 which will not fit in a laptop because most laptops (99.99999%) are 2280 form factor.
these SSD uses full 7 channels and x4 pcie lane, double sided for close to 400GB and close to desktop U.2 P4800x performance, while laptop we get the pathetic optane 800p which is limited to x2 lanes and 600MB/s sequential write, single sided and max at 120GB, very disappointing.
when will we see a DOUBLE SIDED, 4-7+ channel optane memory with x4 3.0 pcie lanes on a m.2 2280 for a fast optane SSD?
Hello olenbr,
Thanks for posting in our community.
Currently, there have been no announcements for a consumer drive that fits the description you've provided.
We appreciate your feedback and will share it with our business unit for consideration.
Eugenio F.
is p4801x 3.3v? where can i find the information for it because if i mod my laptop m.2 slot it can fit 22110 but iirc its only 3.3v for m.2 slots
Hello olenbr,
Please notice this product has not been fully announced, there's no release date or specs announced yet.
However, voltage and other power details can be found on private documentation.
Eugenio F.
hey Intel, so finally Optane 905P m.2 x4 lanes optane SSD is coming out soon with form factor 22110 instead of the consumer regular size 2280, which is fine, and its good that its double sided.
will this SSD be 3.3v? because normally m.2 slots/spec are 3.3v, how does intel plan to have the AIC 905P at 14w 12v work with 3.3v?
Hi olenbr,
Could you please let us know where did you find the information about the Intel® Optane™ SSD 905P Series with form factor 22110? Since we are not offering this option for the SSD, you can find the available form factors https://ark.intel.com/products/series/129835/Intel-Optane-SSD-905P-Series here.
We look forward to hearing back from you.
Junior M.
its currently not yet available as a product but will be soon. it was seen at computex 2018 and intel mentioned it'll be available in this summer.
links are here:
https://www.servethehome.com/intel-optane-905p-380gb-m-2-teased-is-the-optane-you-wanted/ Intel Optane 905P 380GB M.2 Teased is the Optane You Wanted
https://www.anandtech.com/show/12899/intel-previews-m2-optane-ssd-905p-380gb Intel Previews M.2 Optane SSD 905P 380GB
https://www.pcper.com/news/Storage/Computex-2018-Intel-Announces-380GB-Optane-905P-M2-22110-Form-Factor Computex 2018: Intel Announces 380GB Optane 905P in M.2 22110 Form Factor | PC Perspective
Hi olenbr,
We were able to confirm that the launch date for the SSD is early Q3 2018.
However, we are checking the voltage information with our additional resources.
We will keep you posted with any updates.
Junior M.
Hello olenbr,
We would like to inform you that the Intel® Optane™ SSD 905P Series with form factor M.2 22110 will operate at 3.3V.
Please let us know if there is something else we can assist you with.
Junior M.
so when you mentioned Q3 of 2018, is there more of a specific date/time frame?
Q3 is from June to September right? so up until near end of september?
Hello olenbr,
Thanks for the reply.
We would like to inform you that Q3 is from July to September but we don't have the specific release date for the SSDs.
Junior M.
hey Intel. so its already end of August and if Q3 goes up until end of sept it should be releasing this upcoming month? also at FMS flash memory summit Intel didn't really talk about optane m.2 modules at all, its mostly QLC. is this device still coming to consumer?
