Community
cancel
Showing results for
Search instead for
Did you mean:
BLan
Could provide Thermal Model of P4610?
We want to do thermal simulation on our new server product with P4610.
Thermal model file name should be "xxx.pdml"
Thank you,
Jimmy Hsiao
Jimmy.Hsiao@advantech.com.tw
+886-935-589668
Esteban_C_Intel1
Hello BLan,
Thank you for contacting the Intel Communities.
Could you please further elaborate on what is that you want to do or achieve with the thermal model mentioned?
Also, do you currently have a signed NDA with Intel?
Esteban C
A Contingent Worker at Intel
BLan
Hello Esteban C,
Yes, our company, Advantech Co., has signed NDA.
Actually, we have got thermal model of P3700 previously (#327772-003US). However, we want to change to use P4610 on new project.
Current thermal simulation result is fail on P4610 (~80 degree C) in our product, because the criteria of P4610 Ta is only 70 degree C. But it's based on assuming P4610 is a total 15W heat component, no considering P4610 actual heatsink ... etc. w/o thermal model.
So, we want to use FloTHERM thermal model to check component inside the P4610 is actually fail, or not.
Thank you,
Jimmy (BLan)
Hardware Engineer of Advantech Co.
Esteban_C_Intel1
BLan,
Thank you for the confirmation, as this is internal I will send an email to you with the data required.
Esteban C
BLan
Hi Esteban C,
Thank you.
BTW, the SKU we want is P4610 "1.6TB, 2.5inch SSD"
​​​​​​​Jimmy (BLan)
BLan
Hi Esteban C,
Thank you, we have got model from internal mail.
Jimmy (Blan)
Esteban_C_Intel1
BLan,
I am glad to hear you got the information via email.
Esteban C
