Community
cancel
Showing results for
Search instead for
Did you mean:
RRich14
Could there be someyhing wrong with my SSD5- 540s- 240 G
I ran out of space on my last SSD, a Samsung 80 GB. I bought an Intel 540 - 240 GB.
I decided to install the Win 10 Anniversary and like others I've had nothing but freezing. MS support sent me an ISO for the previous version 1511. At this point after a clean install, I'm still I'm freezing up. Before withe the Samsung I had a perfect ruining machine.
I'm thinking that possibly it's the new drive and not Windows. Could it possibly be the issue?
Has anyone had any issues with the 540?
Community Manager
mailto:pbman1953@gmail.com pbman1953@gmail.com,
If your OS experiences slowness or freezing, you may want to take a look at this solution found in this link: http://www.intel.com/content/www/us/en/support/software/000006198.html Run a Low-Level Format on Intel® Solid State Drives
If your Intel® SSD Detects a Security Freeze Lock, please access this other link that provides a solution to this specific matter: http://www.intel.com/content/www/us/en/support/software/000006094.html What to Do if Your Intel® SSD Detects a Security Freeze Lock
*Caution! Always back up your software before you run a low-level format or secure erase
Let us know if this worked for you.
Aleki
RRich14
I took your advice and took the time to use Kill disc. Then I reinstalled and the computer worked fine for a day. Then there was one update but not the newer anniversary version, still the pre- anniversary 1511.
Right after it froze.
Any ideas? Installing the most up to date video drivers don't seem to help
Rich
Community Manager
In this case, could you please run a diagnostic using this tool: https://downloadcenter.intel.com/download/26085/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox and send us the logs so we can check it. In the mean time, you can also do the following procedures:
1. Make sure you have all the latest chipset drivers. Sometimes, certain Windows®10 freeze can be caused by certain BIOS settings such as fast boot. Please disable it and test it in order to see if the situation is resolved.
2. Check for BIOS updates and update it if there is any available.
3. Update your SSD firmware. *Make sure to have a back up of all the relevant information in order to avoid data loss.
Let us know if this helped you.
Aleki
RRich14
My replies are-
Bios is up to date
As far as I know drivers are up to date
I think fast boot is disabled because I see the bios info on boot up. But I will check.
What is the simplest way to update the firmware? I thought the SSD toolbox does that?
Last night I ran the full diagnostic test and walked away for the night. When I came back ,this morning, the screen showed me a "can't find boot disc", I had to shut down and re-start. At the end of the test it may have re-started? Then the boot disc message?
Where would the log be kept?
Community Manager
To obtain the logs from the Intel® SSD Toolbox you can click on the button to the bottom right that says Export. If possible as well, could please try once more and see if you can get the SMART details.
Have you had the opportunity to try this drive in a different system and see if the same thing happens?
Aleki
RRich14
I'll look for the logs and send them in.
I can try the SDD in another machine and see.
Community Manager
Great! We're looking forward to hearing from you soon with the results after trying in another computer and also to get the logs.
Aleki
RRich14
Did the firmware update and here are the logs- They are big
IntelSSDTDK-
[19:58:38:351] INFO : .\Feature.cpp(88): Feature::Feature: OS: WIN8.1
[19:58:38:367] INFO : .\SystemParser.cpp(73): SystemParser::Initialize: Initialized with status: 1.
[19:58:38:367] DEBUG : .\Adapter_NVMe_Win.cpp(126): DeviceManagement::Adapter_NVMe_Win::FindAdapters: Opening Handle to \\.\SCSI0: to test if it is a NVMe BusType
[19:58:38:383] DEBUG : .\Adapter_NVMe_Win.cpp(39): DeviceManagement::Adapter_NVMe_Win::Adapter_NVMe_Win: Opening SCSI path / passthrough for this NVMe Windows adapter
[19:58:38:383] INFO : .\SystemParser.cpp(79): SystemParser::Execute: Executing...
[19:58:38:476] DEBUG : .\Adapter_NVMe_Win.cpp(44): DeviceManagement::Adapter_NVMe_Win::Adapter_NVMe_Win: Setting up passthrough command path / 'drive' for \\.\SCSI0:
[19:58:38:476] DEBUG : .\CommandPath_NVME.cpp(344): DeviceManagement::CommandPath_NVME::TestDevice: CommandPath_NVME::TestDevice win Start...
[19:58:38:476] DEBUG : .\SystemParser.cpp(125): SystemParser::GetOperatingSystem: Getting OS information.
[19:58:38:570] DEBUG : .\CommandPath_NVME.cpp(123): DeviceManagement::CommandPath_NVME::SendOpcodeCore: Calling DeviceIoControl()
[19:58:38:570] ERROR : .\CommandPath_NVME.cpp(137): DeviceManagement::CommandPath_NVME::SendOpcodeCore: OS: 1117 = The request could not be performed because of an I/O device error.
[19:58:38:586] DEBUG : .\CommandPath_NVME.cpp(179): DeviceManagement::CommandPath_NVME::SendOpcodeCore: Done copying back data/buffer, command, and status.
[19:58:38:586] ERROR : .\CommandPath_NVME.cpp(184): DeviceManagement::CommandPath_NVME::SendOpcodeCore: Returning IOCTL fail of 18446744073709550499
[19:58:38:586] DEBUG : .\CommandPath_NVME.cpp(373): DeviceManagement::CommandPath_NVME::TestDevice: CommandPath_NVME::TestDevice win End...
[19:58:38:601] ERROR : .\Adapter_NVMe_Win.cpp(58): DeviceManagement::Adapter_NVMe_Win::Adapter_NVMe_Win: In AdapterNVMeWin constructor, tried to TestDevice() on CommandPath_NVMe, but failed
[19:58:38:601] DEBUG : .\Adapter_NVMe_Win.cpp(161): DeviceManagement::Adapter_NVMe_Win::FindAdapters: \\.\SCSI0: device failed NVMe TestDevice() check
[19:58:38:601] DEBUG : .\SystemParser.cpp(203): SystemParser::GetComputerSystem: Getting computer information.
[19:58:38:601] DEBUG : .\Adapter_NVMe_Win.cpp(89): DeviceManagement::Adapter_NVMe_Win::FindAdapters: Failed to get next portkey at portIndex 1, exiting assuming we are at the end of the scsi key list
[19:58:38:617] DEBUG : .\Adapter_Generic_Win.cpp(1106): DeviceManagement::Adapter_Generic_Win::ScanDrives: Scanning for drives
[19:58:38:617] DEBUG : .\SystemParser.cpp(267): SystemParser::GetCPU: Getting CPU information.
[19:58:38:617] DEBUG : .\Adapter_Generic_Win.cpp(136): DeviceManagement::Adapter_Generic_Win::FindPhysical: Looking for physical drives
[19:58:38:617] DEBUG : .\SystemParser.cpp(324): SystemParser::GetDriverVersions: Getting controller information.
[19:58:38:679] INFO : .\Adapter_Generic_Win.cpp(171): DeviceManagement::Adapter_Generic_Win::FindPhysical: Found device: SCSI\DISK&VEN_WDC&PROD_WD5001AALS-00L3B\4&FA535C2&0&020000
[19:58:38:679] INFO : .\Adapter_Generic_Win.cpp(176): DeviceManagement::Adapter_Generic_Win::FindPhysical: Passed filter criteria
[19:58:38:679] INFO : .\SystemParser.cpp(117): SystemParser::Execute: Passed.
[19:58:38:679] DEBUG : .\Adapter_Generic_Win.cpp(191): DeviceManagement::Adapter_Generic_Win::FindPhysical: Retrieved interface data
[19:58:38:695] DEBUG : .\Adapter_Generic_Win.cpp(229): DeviceManagement::Adapter_Generic_Win::FindPhysical: Connected to the drive
[19:58:38:695] INFO : .\Adapter_Generic_Win.cpp(248): DeviceManagement::Adapter_Generic_Win::FindPhysical: Retrieved the physical drive number: \\.\PHYSICALDRIVE1
[19:58:38:695] DEBUG : .\Adapter_Generic_Win.cpp(254): DeviceManagement::Adapter_Generic_Win::FindPhysical: Creating a Drive
[19:58:38:711] DEBUG : .\Adapter_Generic_Win.cpp(261): DeviceManagement::Adapter_Generic_Win::FindPhysical: Intializing Generic Info
[19:58:38:711] DEBUG : .\DeviceIdentification_System.win.cpp(120): DeviceManagement::DeviceIdentification_System::Identify: DeviceIdentification_System::Identify
[19:58:39:273] DEBUG : .\DeviceIdentification_System.win.cpp(217): DeviceManagement::DeviceIdentification_System::Identify: Additional location info for all drives
[19:58:39:289] INFO : .\DeviceIdentification_System.win.cpp(223): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Lun 0
[19:58:39:289] INFO : .\DeviceIdentification_System.win.cpp(226): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Port 0
[19:58:39:289] INFO : .\DeviceIdentification_System.win.cpp(229): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Target ID 0
[19:58:39:304] INFO : .\DeviceIdentification_System.win.cpp(232): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Path ID 2
[19:58:39:304] DEBUG : .\Adapter_Generic_Win.cpp(264): DeviceManagement::Adapter_Generic_Win::FindPhysical: Extracting firmware revision
[19:58:39:304] DEBUG : .\Adapter_Generic_Win.cpp(275): DeviceManagement::Adapter_Generic_Win::FindPhysical: Detecting command path
[19:58:39:320] INFO : .\Adapter_Generic_Win.cpp(278): DeviceManagement::Adapter_Generic_Win::FindPhysical: Detected command path type: ATA
[19:58:39:320] DEBUG : .\Adapter_Generic_Win.cpp(281): DeviceManagement::Adapter_Generic_Win::FindPhysical: Setting Adapter of this Drive to itself for now
[19:58:39:320] INFO : .\Adapter_Generic_Win.cpp(171): DeviceManagement::Adapter_Generic_Win::FindPhysical: Found device: SCSI\DISK&VEN_INTEL&PROD_SSDSC2KW240H6\4&FA535C2&0&000000
[19:58:39:320] INFO : .\Adapter_Generic_Win.cpp(176): DeviceManagement::Adapter_Generic_Win::FindPhysical: Passed filter criteria
[19:58:39:336] DEBUG : .\Adapter_Generic_Win.cpp(191): DeviceManagement::Adapter_Generic_Win::FindPhysical: Retrieved interface data
[19:58:39:336] DEBUG : .\Adapter_Generic_Win.cpp(229): DeviceManagement::Adapter_Generic_Win::FindPhysical: Connected to the drive
[19:58:39:336] INFO : .\Adapter_Generic_Win.cpp(248): DeviceManagement::Adapter_Generic_Win::FindPhysical: Retrieved the physical drive number: \\.\PHYSICALDRIVE0
[19:58:39:351] DEBUG : .\Adapter_Generic_Win.cpp(254): DeviceManagement::Adapter_Generic_Win::FindPhysical: Creating a Drive
[19:58:39:351] DEBUG : .\Adapter_Generic_Win.cpp(261): DeviceManagement::Adapter_Generic_Win::FindPhysical: Intializing Generic Info
[19:58:39:351] DEBUG : .\DeviceIdentification_System.win.cpp(120): DeviceManagement::DeviceIdentification_System::Identify: DeviceIdentification_System::Identify
[19:58:39:914] DEBUG : .\DeviceIdentification_System.win.cpp(217): DeviceManagement::DeviceIdentification_System::Identify: Additional location info for all drives
[19:58:39:914] INFO : .\DeviceIdentification_System.win.cpp(223): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Lun 0
[19:58:39:914] INFO : .\DeviceIdentification_System.win.cpp(226): DeviceManagement::DeviceIdentification_System::Identify: This drive has a Port 0
[19:58:39:929] INFO : .\DeviceIdentification_System.win.cpp(229): DeviceManagement...
Community Manager
We also need the logs from the toolbox. Could you please be so kind and provide the logs extracted from it? Just click on the button that says " Export " in order to create an Excel file and once you have done that, please attach it here. Also, let us know if you had the opportunity to try this drive in a different computer as well.
Aleki
RRich14
I tried that but it didn't go to the right place on my computer. But in the end I returned the drive. I couldn't handle it any more. I still believe in the excellence of Intel products!
Thanks for you help!
Community Manager
mailto:pbman@gmail.com pbman@gmail.com,
Thank you for your preference and trust in our products. Here is a list of other Intel® SSDs that you be interested to know about them. It is important to consult with your computer manufacturer for compatibility in order to enjoy SSD full functionalities.
Consumer SSDs
http://ark.intel.com/compare/71181,71180,71179,74497,71183 Intel® SSD 525 Series
http://ark.intel.com/compare/86741,86739,88743,88744,86742,86740 Intel® SSD 750 Series
http://ark.intel.com/compare/81039,81038 Intel® SSD 730 Series
http://ark.intel.com/compare/94917,94921,94924,94926 Intel® SSD 600p Series
http://ark.intel.com/compare/94204,94421,94209,94434,94207,94331,94203,94328,94213,94334,94420,94332 Intel® SSD 540s Series
http://ark.intel.com/compare/86729,86722,86737,86728,86734,86725,86731,86727,86738,89330 Intel® SSD 535 Series
http://ark.intel.com/compare/75336,77950,75334,75333,75331,75328,75338,77949,75613,75611,75337,77948... Intel® SSD 530 Series
Check this link if you would like to see other types of SSDs : http://ark.intel.com/# @SolidStateDrives
Aleki
