cancel
Showing results for
Search instead for
Did you mean:
Critical performance drop on newly created large file
ANaza
New Contributor II
  • NVMe drive model: Intel SSD DC P3700 U.2 NVMe SSD
  • Capacity: 764G
  • FS: XFS
  • Other HW:
    • AIC SB122A-PH
    • 8 Intel NVMe DC P3700 2 on CPU 0, 6 on CPU 1
    • 128 GiB RAM (8 x 16 DDR4 2400Mhz DIMMs)
    • 2 x Intel E5-2620v3 2.4Ghz CPUs
    • 2 x Intel DC S2510 SATA SSDs (one is used a system drive).
    • Note that both are engineering samples provided by Intel NSG. But all have had the latest firmware updated using isdct 3.0.0.
  • OS: CentOS Linux release 7.2.1511 (Core)
  • Kernel: Linux fs00 3.10.0-327.22.2.el7.x86_64 # 1 SMP Thu Jun 23 17:05:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
We have been testing two Intel DC P3700 U.2 800GB NVMe SSDs to see the impact of the emulated sector size to throughput (512 vs 4096). Using fio 2.12, we observed a puzzling collapse of performance. The steps are given below.
Steps:
1. Copy or write sequentially single large file (300G or larger)
2. Start fio test with the following config:
[readtest]
thread=1
blocksize=2m
filename=/export/beegfs/data0/file_000000
rw=randread
direct=1
buffered=0
ioengine=libaio
nrfiles=1
gtod_reduce=0
numjobs=32
iodepth=128
runtime=360
group_reporting=1
percentage_random=90
3. Observe extremely slow performance:
fio-2.12
Starting 32 threads
readtest: (groupid=0, jobs=32): err= 0: pid=5097: Thu Jul 14 13:00:25 2016
read : io=65536KB, bw=137028B/s, iops=0, runt=489743msec
slat (usec): min=4079, max=7668, avg=5279.19, stdev=662.80
clat (msec): min=3, max=25, avg=18.97, stdev= 6.16
lat (msec): min=8, max=31, avg=24.25, stdev= 6.24
clat percentiles (usec):
| 1.00th=[ 3280], 5.00th=[ 4320], 10.00th=[ 9664], 20.00th=[17536],
| 30.00th=[18816], 40.00th=[20352], 50.00th=[20608], 60.00th=[21632],
| 70.00th=[21632], 80.00th=[22912], 90.00th=[25472], 95.00th=[25472],
| 99.00th=[25472], 99.50th=[25472], 99.90th=[25472], 99.95th=[25472],
| 99.99th=[25472]
lat (msec) : 4=3.12%, 10=9.38%, 20=25.00%, 50=62.50%
cpu : usr=0.00%, sys=74.84%, ctx=792583, majf=0, minf=16427
IO depths : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
issued : total=r=32/w=0/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0
latency : target=0, window=0, percentile=100.00%, depth=128
Run status group 0 (all jobs):
READ: io=65536KB, aggrb=133KB/s, minb=133KB/s, maxb=133KB/s, mint=489743msec, maxt=489743msec
Disk stats (read/write):
nvme0n1: ios=0/64317, merge=0/0, ticks=0/1777871, in_queue=925406, util=0.19%
4. Repeat the test
5. Performance is much higher:
fio-2.12
Starting 32 threads
readtest: (groupid=0, jobs=32): err= 0: pid=5224: Thu Jul 14 13:11:58 2016
read : io=861484MB, bw=2389.3MB/s, iops=1194, runt=360564msec
slat (usec): min=111, max=203593, avg=26742.15, stdev=21321.98
clat (msec): min=414, max=5176, avg=3391.05, stdev=522.29
lat (msec): min=414, max=5247, avg=3417.79, stdev=524.75
clat percentiles (msec):
| 1.00th=[ 1614], 5.00th=[ 2376], 10.00th=[ 2802], 20.00th=[ 3097],
| 30.00th=[ 3228], 40.00th=[ 3359], 50.00th=[ 3458], 60.00th=[ 3556],
| 70.00th=[ 3654], 80.00th=[ 3785], 90.00th=[ 3949], 95.00th=[ 4080],
| 99.00th=[ 4359], 99.50th=[ 4424], 99.90th=[ 4752], 99.95th=[ 4883],
<e...
22 REPLIES 22
Esteemed Contributor III
Hi AlexNZ,
Please share any findings from the kernel communities, we will be waiting for your response.NC
ANaza
New Contributor II
Hello
Today I managed to reproduce the same issue on simple SSD (Intel DC S2510 SATA) with the same behaviour. It indirectly proves my version which blames Linux Kernel.
But I doubt I'll escalate this issue to Kernel community because of the reasons I mentioned above.
Alex
AlexNZ,
Thanks a lot for sharing all your findings. We encourage other customers to post any other questions as well.Have a nice day.NC
