cancel
Showing results for
Search instead for
Did you mean:
DC P3600 Series running at half speed
cmeit
New Contributor II
Just bought new kit.
Intel DC P3600 Series 800GB SSD PCI-e Adaptor Card Solid State Drive (SSDPEDME800G401)
Asus Xonar DX 7.1 PCI-Express Sound Card
Intel Core i7 5930K
32GB (4x8GB) DDR4 2400MHz Quad Channel Kit
Asus X99-S Intel X99 (Socket 2011) DDR4 ATX Motherboard
Microsoft Windows 8.1 64 Bit
2 x SLI GTX 980 video cards
System works fine. Intel SSD is configured with 8.1 and works will all the software
All bench testing on the components with PassMark shows they are all working fine except for the SSD which is only performing at 800Meg/s
I tried also using Atto bench test and got the same results. The drive is running slower than expected.
All the correct Intel drivers are installed. The Intel test package says it is working OK and link power manager is enabled.
However is read/write benchmarks are less than a 1/3 of what you would expect/ Any ideas guys, is it to do with not enough PCIe lanes being free ??
Any suggestions would be greatly appreciated
40 REPLIES 40
cmeit
New Contributor II
The DRAM is standard, not certain about the sound card, it is the top of the range latest Asus Zonar.
Kei_K_Intel
New Contributor III
New Contributor III
Okay thanks for response... Any chance you can change PCIe slot you are running the SSD in? (I realize that may be a pain, but I've seen differences in different slot with various motherboards
Kei_K_Intel
New Contributor III
New Contributor III
Is this the sound card you have?
http://www.asus.com/us/Sound_Cards_and_DigitaltoAnalog_Converters/Xonar_DX/ http://www.asus.com/us/Sound_Cards_and_DigitaltoAnalog_Converters/Xonar_DX/
it says this card was designed for XP and Vista... I suspect this is an older card... Just for debug purposes, can you disconnect this device?
cmeit
New Contributor II
Hi Psig,
Ran the tool and it has amazing info on the system. Massive report with thousands of bits of data. Where do I find the data you want to look at on the report. Tons of info on secondary hard drive but only one line on the Intel SSD
Drive Model:NVMe INTEL SSDPEDME80 Drive Revision:8DV1 Device Type:Disk drive
Kei_K_Intel
New Contributor III
New Contributor III
Awesome! Unfortunately, the system summary page is only a summary.. you will need to do a full export to get all the information
Look for an "export" function (maybe on another window related to the tool)... Export it to however format you like... (I prefer .xml). You will have to scroll down about halfway... Start looking for PCIe Devices... look to see what Gen speed they are functioning at.
