cancel
Showing results for
Search instead for
Did you mean:
DC P3600 and HP DL380Gen9
PPaul14
New Contributor
Hello
Sorry if this has been asked before, but I cannot find any good information
I would like to know if the DC P3600 PCIe SSD is compatible with the new Gen9 DL380?
And if someone has used this can I know how it ran
4 REPLIES 4
Esteemed Contributor III
paul@norac,
The Intel® SSD DC P3600 Series (XGB, 2.5in PCIe 3.0, 20nm, MLC) is designed to be used in enterprise operating systems. Technically, this drive is compatible according to this online documentation: http://www8.hp.com/h20195/v2/getpdf.aspx/c04346247.pdf HPE ProLiant DL380 Generation9 (Gen9) page # 24 shows HP* DL380 NVMe* SSD Express Bay Kit Compatibility and page # 34 shows all HPE SSD compatibility. However, you need to consider the OS used and the purpose to use the SSD.For further information on this subject, we recommend to contact your nearest HP* reseller in order to find out more. For your convenience, here is a link where you can locate the nearest one: https://findapartner.hpe.com/ Find a PartnerThis other link may be helpful as well: https://iotsolutionsalliance.intel.com/solutions-directory/hp-proliant-dl380-gen9 HP* PROLIANT DL380 GEN9Let us know if there is anything else we can do to assist you.Best regards,Aleki
PPaul14
New Contributor
Aleki
Thanks for the reply
Unfortunately HP resellers always say if its not HP we cannot say if it will work or not
And yes, we will be running Server 2012R2 and HyperV
Its unfortunate that such a high end product(the drive) does not have a server compatibility list with vendors such as HP
Paul
paul@norac,
Regrettably there is no documentation regarding third-party product compatibility. However, the Intel® SSD DC P3600 Series is compatible with Windows* Server 2012 R2 as you can confirm here: http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3600-spec... Intel® SSD DC P3600 Series - PRODUCT SPECIFICATION (first page)Please, let us know if there is anything else we can do to assist you.Best regards,Aleki
paul@norac,
We haven't heard from you in a while so we would like to know if there is anything else we can do to assist you.Best regards,Aleki
