Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DC S3520 1.2TB (SSDSC2BB012T701) compatible with LSI9361
Hello
Anyone has the new DC S3520 3D-NAND running with LSI (9361) controller ?
Till now it isn't in the HCL from LSI (think it is to new for the HCL)
cu
Community Manager
Hello Hannes_at,
We understand that you would like us to help you confirm hardware compatibility between the Intel® SSD DC S3520 Series and the LSI* 9361 RAID controller.
This SSD series was only released back in late August 2016, so it's normal to find that many hardware vendors may not have yet added it to their hardware compatibility lists.
That being said, despite using the new 3D NAND storage technology, at the end of the day, this is simply a high endurance SATA drive. We would not expect you to run into any unusual hardware compatibility issues. Yet, recommendation is to always contact the hardware manufacturer to check if they have validated our drive using their controller.
Carlos A.
