cancel
Showing results for
Search instead for
Did you mean:
DC S3700 and vmware esx
Esteemed Contributor III
We want to use fast and reliable SSD drives for our Vmware vSphere 4 Host in a VDI solution. I understand that there is no TRIM support in VMware, so i assume that the write amplification will be higher than using trim support.How does that result in performance and reliablity for these new DC S3700 drive? Am I able to write the drive for example 5 times a day for 5 years and will the performance not degrade over time?
0 REPLIES 0
