Community
cancel
Showing results for
Search instead for
Did you mean:
JHill14
Data Migration System Hang After Reboot
Migrating Windows 8.1 on a new Dell XPS 8700 to Intel 520 Series.
Using the Intel Data Migration Software, I get can the process to the reboot, after selecting the target and destination drives for the data migration. I then see the Acronis software trademark and a DOS screen for a split second, but then the computer freezes on a screen showing "Intel Data Migration Software; Processing, please wait." There's an hourglass but I can't move it as in Windows.
I've tried turning off antivirus and firewall software, disconnecting Internet access, and running the program as administrator, nothing seems to works.
Thank you in advance!
Jose_H_Intel1
I suggest you connecting the Intel® SSD to the Intel® Chipset / SATA controller (usually SATA port 0, consult your system's documentation). If you are trying to connect the drive via USB, please make sure the Intel® SSD 520 is properly identified as such and not detected as a generic USB/SATA drive; otherwise you may need to change the USB adapter cable.
There is the possibility that another peripheral interferes with the process. You may want to disconnect other devices or connecting the keyboard and mouse to USB 2.0 ports.
http://www.intel.com/support/ssdc/hpssd/sb/CS-034081.htm Intel® High Performance Solid-State Drives — Data Migration FAQs
