Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Data migration software problem (destination drive greyed out)
brad
I just bought an Intel 530 120GB SSD to replace my old 500GB HDD.
On the HDD i have 3 partition from which the first one, the one with the operation system i want to migrate the SSD.
I use Intel Data Migration software, i complete all the steps, but when i have to select the destination drive, it all greyed out.
I attached a screenshot.
What could be the problem?
brad
I forgot to mention that the partition i want to migrate is 100GB
Kevin_M_Intel
Hi bograd,
I am sorry for your trouble but let me help you.
I would like to get more information about the system configuration you have so can you please provide the following?
  1. IS the SSD connected directly to the SATA ports or is it USB connected?
  2. Is the SSD connected to an Intel® SATA port controller or Marvel?
  3. What is the brand and model of the computer?
  4. Is your computer running the latest BIOS? If so, what is the version installed?
Kevin M
brad
1. Directly to the motherboard's sata3 port
2,3. Gigabyte motherboard ga-b75m-d3v
4. yes
Anyway i solved the problem using AOMEI Partition Assistant which worked flawlessly.
