Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
Dear Sirs, we have IBM server flex x240 ,we need to upgrade hdd hard to ssd (Intel), so could you please recommend me which model of Intel its compatible with my server thanks
phama
JosafathB_Intel
Hello, phama,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance with your “IBM* server flex x240”, If we infer correctly we will appreciate if you can review the following information:
•   We suggest you contacting your OEM (original equipment manufacturer) in this case IBM*(Lenovo*) to get a list of compatible and tested hardware.
•   In the following link there is a list of compatible hardware provided by your PC manufacturer:
https://lenovopress.com/tips0860-flex-system-x240-compute-node-8737-e5-2600#internal-drive-options
•   In this link you can see that there are several Intel® SSDs as the S3700 series and the S3500 series the main difference between this drives and the Intel® generic drives that you can purchase from any Intel® distributor will be the firmware that in the case of the ones provided by your OEM it is modified to work with your PC.
•   Please check your hardware specification before purchasing any of our “Datacenter SSD” (DC) since we cannot assure you that they will be compatible with your PC. The whole list of our DC SSDs is the following https://ark.intel.com/content/www/us/en/ark.html#@PanelLabel83425.
Please confirm compatibility with your OEM first before installing any of this drives
We hope you find this information helpful.
We will be looking forward to your reply in case you need further assistance.
Have a nice day.
Josh B.
Under Contract to Intel Corporation
Third-Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use, you agree that you must evaluate, and bear all risks associated with, the use of any third-party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site-specific terms.
JosafathB_Intel
Hello, phama,
Have a nice day.
Josh B.
JosafathB_Intel
Hello, phama,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Hello, phama,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this case.
We will be looking forward to your reply.
Josh B.
