According Toolbox version 3.3.0 SSD 750 unit is degraded have the latest drivers after formatting of NVMe and continuous pc alike is new
Hello Romesa74,
Please provide additional details, so we can get a better understanding of this condition:
Computer make and model
Motherboard model and BIOS version
Operating system (including 32 or 64 bit)
Driver version used
SSD model
Is this an Add in card, or a 2.5 in SSD?
Where exactly are you getting the message? provide a screenshot if possible.
Aside from the warning in the toolbox, have you noticed any other issues with the drive?
Also, we would like to get the Toolbox export log, please follow these instructions to retrieve it:
- Open Intel® SSD Toolbox.
- Stay in the Homepage of the tool, or navigate back to it using the "Home" button.
- Click the Export button in the bottom–right section of the Toolbox.
- Enter a file name, make note of the file location and click on "Save".
'ID', 'Descripción', 'Crudo', 'Normalizado', 'Umbral', 'Acción'
AB, Program Fail Count, 0, 100, , Listo para usar.
AC, Erase Fail Count, 0, 100, , Listo para usar.
AD, Específico del proveedor, 0xB000F0009, 100, , Listo para usar.
, Minimum erase cycles, 9, , ,
, Maximum erase cycles, 15, , ,
, Average erase cycles, 11, , ,
B8, End-to-End Error Detection Count, 0, 100, , Listo para usar.
C7, CRC Error Count, 13, 100, , Listo para usar.
E2, Timed Workload - Media Wear, 277, 100, , Listo para usar.
E3, Timed Workload - Host Read/Write Ratio, 57, 100, , Listo para usar.
E4, Timed Workload Timer, 21238, 100, , Listo para usar.
EA, Thermal Throttle Status, 0x0, 100, , Listo para usar.
, Throttle status (%), 0, , ,
, Throttling event count, 0, , ,
, Reserved, 0, , ,
F0, Retry Buffer Overflow Count, 0, 100, , Listo para usar.
F3, PLI Lock Loss Count, 0, 100, , Listo para usar.
'Palabra', 'Descripción', 'Valor'
0-7, Namespace Size, 0x8BBA0CB0
8-15, Namespace Capacity, 0x8BBA0CB0
16-23, Namespace Utilization, 0x8BBA0CB0
24, Namespace Features, 0x0
, - Bit 7-1: Reserved, 0
, - Bit 0: Thin Provisioning Support, 0
25, Number of LBA Formats, 6
26, Formatted LBA Size, 0
, - Bit 7-5: Reserved, 0
, - Bit 4: Metadata transfer bit, 0
, - Bit 0-3: LBA Format Support, 0
27, Metadata Capabilities, 1
, - Bit 7-2: Reserved, 0
, - Bit 1: Metadata transfered as part of a separate buffer support, 0
, - Bit 0: Metadata transfered part of extended data LBA Support, 1
28, End-to-end Data Protection Capabilities, 11
, - Bit 4: Protection Info transfered as last 8 bytes of metadata Support, 1
, - Bit 3: Protection Info transfered as first 8 bytes of metadata Support, 0
, - Bit 2: Protection Type 3 Support, 0
, - Bit 1: Protection Type 2 Support, 0
, - Bit 0: Protection Type 1 Support, 1
29, End-to-end Data Protection Type Settings, 0
, - Bit 7-4: Reserved, 0
, - Bit 3: Protection Information Transfer, 0 (Transferred as the last eight bytes of metadata.)
, - Bit 2-0: Protection Type Information, 0 (Protection Information is not enabled)
131-128, LBA Format 0 Support, 0x2090000
, - Bit 31-26: Reserved, 0x0
, - Bit 25-24: Relative Performance, 0x2 (Good performance)
, - Bit 23-16: LBA Data Size, 0x9
, - Bit 15-0: Metadata Size, 0x0
135-132, LBA Format 1 Support, 0x2090008
, - Bit 15-0: Metadata Size, 0x8
139-136, LBA Format 2 Support, 0x2090010
, - Bit 15-0: Metadata Size, 0x10
143-140, LBA Format 3 Support, 0xC0000
, - Bit 25-24: Relative Performance, 0x0 (Best performance)
, - Bit 23-16: LBA Data Size, 0xC
147-144, LBA Format 4 Support, 0xC0008
151-148, LBA Format 5 Support, 0xC0040
, - Bit 15-0: Metadata Size, 0x40
155-152, LBA Format 6 Support, 0xC0080
, - Bit 15-0: Metadata Size, 0x80
159-156, LBA Format 7 Support, 0x0
, - Bit 23-16: LBA Data Size, 0x0
163-160, LBA Format 8 Support, 0x0
167-164, LBA Format 9 Support, 0x0
171-168, LBA Format 10 Support, 0x0
175-172, LBA Format 11 Support, 0x0
179-176, LBA Format 12 Support, 0x0
183-180, LBA Format 13 Support, 0x0
187-184, LBA Format 14 Support, 0x0
X...
