Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Dell mini 9 ssd replacement
Community Manager
I Just bought a new Intel 311 series 20GB ssd for my daughters dell mini 9 to replace the original 8GB and the netbook wont power up with it in it can anyone help ??
MBall5
New Contributor II
On this specific case I suggest you to try updating the bios of your computer and see if that help, take into consideration that the 311 series of ssds are mSATA form factor, make sure that your system support this type of connection, on any case the recommendation here is to contact the system manufacturer for further assistance.
