Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Different between A+B Stepping Intel X25 G2
I have found this List.
Intel X25-M 80GB SATA Solid State Drive (7mm), A stepping (SSDSA2MH080G201)
Intel X25-M 80GB SATA Solid State Drive (7mm), B stepping (SSDSA2MJ080G201)
Intel X25-M 80GB SATA Solid State Drive (9.5mm), A stepping (SSDSA2MH080G2C1)
Intel X25-M 80GB SATA Solid State Drive (9.5mm), B stepping (SSDSA2MJ080G2C1)
Intel X25-M 80GB SATA Solid State Drive (9.5mm Retail) (SSDSA2MH080G2R5)
http://intel.seminars.net/flex/CurrentPointsEarningMatrix.pdf
What is the different between a stepping and b stepping ?
Tags (1)
Steve_Lionel
Black Belt Retired Employee
A stepping, in the semiconductor industry, means a revision of one of the integrated circuits - probably the controller chip. Such revisions are usually to correct errors (er - "errata"). Intel publishes errata lists for its CPUs but may not for the SSD controllers. There won't be any functionality difference. Might just be a timing cleanup or some such. I can see that the product SKU changed.
It's also possible that it's a revision to the circuit board - trace change, part change, etc.
Community Manager
jonat wrote:
A http://www.starbike.com/php/catalogue.php?lang=en&manufacturer=Campagnolo stepping, in the semiconductor industry, means a revision of one of the integrated circuits - probably the controller chip. Such revisions are usually to correct errors (er - "errata"). Intel publishes errata lists for its CPUs but may not for the SSD controllers. There won't be any functionality difference. Might just be a timing cleanup or some such. I can see that the product SKU changed.
What do you mean with "SKU" ? Greetings TommyBoy
Community Manager
SKU means "part number" or "model number", e.g. SSDSA2MH080G201.
