Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Discrepancy in End-to-End Error Detection Threshold
I have a SSD 520 Series 180GB. Firmware version is LCSi.
The SMART attributes reported by the SSD Toolbox says the B8 End-to-End Error Detection Count threshold is "97". However, the Help information says the threshold is "90".
Is this a problem?
Any guidance is appreciated.
Jim
KenF_Intel
Hi Jim,
The discrepancy should not be an issue, but the firmware version on your drive indicates that the drive is a pre-production unit. You will need to check with your source for the SSD for support.
