cancel
Showing results for
Search instead for
Did you mean:
Do I need to find drivers for my Intel x-25v 40gig ssd in my new build?
Esteemed Contributor III
I built a HTPC, my BIOS finds the Intel ssd, but Windows 7 (64 bit) can't find any drives on which to load the OS. Gigabyte (my mobo) says I should get drivers from Intel. During the OS installation, I have the option to look for drivers.
I would think that the Win 7 disc would have all the necessary drivers but I am trying anything now. Here's my setup:
CPU - Intel i3 540
Mobo - Gigabyte GA H55M USB 3 REV 2.0
hhd - Intel x-25v 40 gig ssd
I put the ssd is on the SATA2_0 port; I have the optical on the gSATA2_5 port. There are no other drives in the system. If it matters, there is no graphics card as I'm using the i3 for graphics.
SATA is set to AHCI in the BIOS. As it boots, I see a quick screen identifying the ssd and the dvd. I can boot into the Win 7 disc and it starts installation but when it gets to the screen where I'm to select a drive, there aren't any displayed. I get a box stating "no drives were found". It says I should install a cd, dvd, or usb drive to load drivers.
I have changed ports, changed SATA cables, removed the ssd and formatted it on another computer - I'm pretty sure that the problem is not the port, cable, or the ssd. I have changed the port to IDE and back again to AHCI but nothing works - it can never find a drive.
I find it hard to believe that the Win 7 disc doesn't have the drivers. But short of anything else, are there 'special' ssd drivers I should be using? Any other suggestions (other than I should have selected an Intel board)?
thank you,
Alan
16 REPLIES 16
Can't blame you airpoll, I understand. I guess you just got a bad one, I have four Intel G2's and they were all fine from day one. Hopefully your experience does not become a trend for these drives. Enjoy your new drive!
Thank you
