Community
cancel
Showing results for
Search instead for
Did you mean:
TNguy230
Do Intel SSD drives have appropriate Arm64 tooling to allow us to do an in-place firmware upgrade?
We use these drives (Intel Part Number: SSDSC2BB012T701 - 1.2 TB SATA SSD, and SSDPE2KE016T7 - 1.6 TB 2.5 NVMe SSD) in our Arm64 Server (Lenovo HR350A). Wondering if Intel drives have appropriate Arm64 tooling to allow us to do an in-place firmware upgrade? We would like to avoid physically pulling drives and attaching them to an x86 system to upgrade the firmware.  Basically do you have a firmware upgrade tool for the Arm64 Servers?
-Tinh
JosafathB_Intel
Hello TNguy230,
Thank you for contacting Intel® Memory & Storage Support.
We are going to be working on reviewing your inquiry about “if Intel drives (Intel® SSD DC P4600 Series) have appropriate Arm64 tooling to allow us to do an in-place firmware upgrade”. We will be contacting you back as soon as we have an update or in case further information is required.
Thank you for your patience and understanding.
Josh B.
A Contingent Worker at Intel
JosafathB_Intel
Hello TNguy230,
Thank you for your patience.
We were reviewing some documentation related to your system (https://amperecomputing.com/wp-content/uploads/2019/01/Lenovo_ThinkSystem_HR350A_20190118.pdf) according to your OEM (original equipment manufacturer) one of the operating systems (OS) that are supported by your server is “CentOS 7.5”.
The only tool available to update the firmware for Data Center drives is the “Intel® SSD Data Center Tool” (https://downloadcenter.intel.com/download/28999/Intel-SSD-Data-Center-Tool-Intel-SSD-DCT-?product=87...) and the compatible listed versions of “CentOS are 7.4 and 7.2”.
This been said we cannot assure you that this tool will run as expected in your system, please feel free to try to install this software and to check if it works in the version of the OS that you have installed in your Lenovo server and if it works to try to update the SSD firmware.
We advise you to consult your OEM Lenovo* regarding the compatibility of this drive with your server system.
We will be looking forward to your reply letting us know the results.
Josh B.
JosafathB_Intel
Hello TNguy230,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your community thread remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Hello TNguy230,
Thank you for having contacted Intel® Technical Support.
I was reviewing your community post and we would like to know if you need further assistance or if we can close this community thread.
We will be looking forward to your reply.
Josh B.
TLars
Hi Josh,
I received e-mail with Subject "** FIRMWARE update needed ** - Intel SATA SSDs S4610 & S4510, *only* with sizes 1.92TB & 3.84TB"
I have a mixed heterogeneous environment with various hardware. Among them I have 4 qty R281-T94 nodes with a total of 16 qty 1.92TB S4610's.
Running Ubuntu 18.04.3 LTS with 4.15.0-72-generic aarch64.
Any suggestions on how to update all the drives? All are affected.
oot@n005:~# smartctl -x /dev/sdb
smartctl 6.6 2016-05-31 r4324 [aarch64-linux-4.15.0-72-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:   INTEL SSDSC2KG019T8
Serial Number:  PHYG850000ME1P9DGN
LU WWN Device Id: 5 5cd2e4 150613cad
Firmware Version: XCV10100
User Capacity:  1,920,383,410,176 bytes [1.92 TB]
Sector Sizes:   512 bytes logical, 4096 bytes physical
Rotation Rate:  Solid State Device
Form Factor:   2.5 inches
Device is:    Not in smartctl database [for details use: -P showall]
ATA Version is:  ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Mon Dec 16 14:00:40 2019 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:  Unavailable
APM feature is:  Unavailable
Rd look-ahead is: Enabled
Write cache is:  Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
Brgds,
ToreL
