cancel
Showing results for
Search instead for
Did you mean:
Does 730 use HET or SET MLC?
ppara5
Contributor
The 3700, 3710, and 3610 all use High Endurance Technology (HET) MLC, with the first using 25nm and the other two using 20nm. The 3510 uses Standard Endurance Technology (SET) MLC. The 730 uses 20nm Compute-Quality Components. So which type of MLC does the 730 use: HET or SET?
1 ACCEPTED SOLUTION
jbenavides
Valued Contributor II
Hello paramountain,
The Intel® SSD 730 Series uses Standard Endurance Technology.
It is a high performance client SSD, recommended for PC enthusiast and Workstation systems. The Intel® SSD 730 Series provides better performance and endurance than other client SSD's.
It does not feature High Endurance Technology (HET) as noted in the http://ark.intel.com/products/81038/Intel-SSD-730-Series-240GB-2_5in-SATA-6Gbs-20nm-MLC Intel® SSD 730 Series (240GB, 2.5in SATA 6Gb/s, 20nm, MLC) Specifications
6 REPLIES 6
jbenavides
Hello paramountain,
Thanks for the reply. Yes, the Ark page does indeed state that the 730 does not employ HET. I would never have guessed that the Ark page contained data that the product brief PDF omitted. http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ssd-730-series-brief.pdf http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ssd-730-series-brief.pdf
The Ark page brought up another question. It states that the 730 does not have "Enhanced Power Loss Data Protection." However, the photos at Storage Review show that the 730 has the same red capacitors that the 3700 has. Does "Enhanced Power Loss Data Protection" imply more than two capacitors or does the Ark page contain a misprint?
http://www.storagereview.com/intel_ssd_730_series_review Intel SSD 730 Series Review | StorageReview.com - Storage Reviews
http://www.storagereview.com/intel_ssd_dc_s3700_series_enterprise_ssd_review Intel SSD DC S3700 Series Enterprise SSD Review | StorageReview.com - Storage Reviews
jbenavides
The Intel® SSD 730 Series incorporates power loss protection circuitry, capacitors and firmware support to help protect user data.
All data that has been completely transferred over the SATA Phy and acknowledged on the SATA Transport from the the drive to the host will be written to NAND.
Thanks for the reply. So the Ark page for the 730 is in error and should say "Yes" for "Enhanced Power Loss Data Protection."
