Community
cancel
Showing results for
Search instead for
Did you mean:
anaps
Does Intel 730 SSD series supports encryption (AES-256)
Jump to solution
I was wandering about the Intel 730 SSD encryption functionality.
In this document http://www.intel.com/content/www/us/en/solid-state-drives/ssd-730-series-spec.html 730 Series Specification any kind of encryption support is not mentioned, although in other product series e.g Intel ssd 520 that information is clearly http://download.intel.com/newsroom/kits/ssd/pdfs/intel_ssd_520_product_spec_325968.pdf written http://download.intel.com/newsroom/kits/ssd/pdfs/intel_ssd_520_product_spec_325968.pdf
However, from this page we can understand that Hardware encryption is supported http://ark.intel.com/de/products/81038/Intel-SSD-730-Series-240GB-2_5in-SATA-6Gbs-20nm-MLC ARK | Intel® SSD 730 Series (240GB, 2.5in SATA 6Gb/s, 20nm, MLC)
Thanks in advance.
KenF_Intel
Hi Napso,
Yes, the Intel® SSD 730 drives do support 256-bit AES encryption. We are in the process of updating the specification documents to have the correct information.
KenF_Intel
Hi Napso,
anaps
Thank you for your replay.
A more general question. Is there a way that we can test if an SSD drive is encrypted?
Thanks in advance.
jbenavides
Hello Napso,
You should be able to check the encryption status from the management interface of the tool you use to encrypt your drives.
Keep in mind that some applications use the Windows/domain credentials to encrypt and unlock the drive, and others may request an additional password for it.
An encrypted SSD would not be readable to others if the password is not provided, even if it is used as a secondary drive in other computers.
jbenavides
If your inquiry is regarding the Onboard Encryption built into the SSD. There is no easy way to confirm that the data on drive's memory is encrypted, as it happens automatically inside the SSD.
Our Solid State Drives have have to pass a certification test before they are released to the market and advertised as conforming to the AES standard.
SRyan3
AES encryption by itself is not good enough these days, I just bought this drive and I want to use DiskCryptor to encrypt is with AES-Twofish-Serpent algorithm combination, does anyone forsee any issues? All drives in my system will use this encryption. Thanks
jbenavides
Hello Sixjac,
We would not expect any conflicts between the AES encryption in the Intel® Solid-State Drive 730 Series, and other algorithms used by 3rd party encryption software. However, Intel does not test 3rd party software on the drives, so we strongly advise you to check with the Diskcryptor team if there are any special requirements for the software to work with SSDs.
*NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
https://diskcryptor.net/wiki/Main_Page https://diskcryptor.net/wiki/Main_Page
