Community
cancel
Showing results for
Search instead for
Did you mean:
mpier3
Does Intel 750 Series works with Linux (ubuntu distro) ?
Hello everybody,
I'm really interested into Intel's new SSD and I would like to know if it works with Ubuntu ?
ASouz7
Hello maverick8001,
We have successfully booted a number of Linux distributions. You will need the latest version that included NVMe in the kernel (3.10).
JCant4
Aleki_intel,
Can you confirm that means I have to update kernel from 2.6.32 to 3.10 (3.19 reccommended) to even see the devive.
This isn't possible for me due to other software issues.
Right now I can't see Intel 750 with lcpsi on ASUS Z9PE-D8WS motherboard with recent bios. Did I miss that device in Slot 2? There are so many Intel devices on this system it is hard to locate 750.
Output from lspci -v below (dual CPU dual Graphics)
00:00.0 Host bridge: Intel Corporation Xeon E5 v2/Core i7 DMI2 (rev 04)
Subsystem: ASUSTeK Computer Inc. Device 84f0
Flags: fast devsel
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [280] Vendor Specific Information: ID=0005 Rev=3 Len=018 <?>
00:01.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1a (rev 04) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Capabilities: [40] Subsystem: ASUSTeK Computer Inc. Device 84f0
Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
Capabilities: [90] Express Root Port (Slot+), MSI 00
Capabilities: [110] Access Control Services
Capabilities: [148] Advanced Error Reporting
Capabilities: [250] # 19
Kernel driver in use: pcieport
Kernel modules: shpchp
00:01.1 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 1b (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:02.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:02.2 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 2c (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
Memory behind bridge: b4000000-b40fffff
00:03.0 PCI bridge: Intel Corporation Xeon E5 v2/Core i7 PCI Express Root Port 3a (rev 04) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: a8000000-b30fffff
00:05.0 System peripheral: Intel Corporation Xeon E5 v2/Core i7 VTd/Memory Map/Misc (rev 04)
Flags: fast devsel
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
00:05.2 System peripheral: Intel Corporation Xeon E5 v2/Core i7 IIO RAS (rev 04)
Flags: fast devsel
00:05.4 PIC: Intel Corporation Xeon E5 v2/Core i7 IOAPIC (rev 04) (prog-if 20 [IO(X)-APIC])
Memory at b310b000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Express Root Complex Integrated Endpoint, MSI 00
00:11.0 PCI bridge: Intel Corporation C600/X79 series chipset PCI Express Virtual Root Port (rev 06) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
I/O behind bridge: 00009000-00009fff
Memory behind br...
ASouz7
Makaira,
The Intel(R) SSDs requires kernel 3.19. Any other version below this one we cannot guarantee. Please check this document for reference.
APopo4
@aleki_intel, we bought several 750 nvme ssds, ubuntu is 15.04, kernel is 3.19. lsblk doesn't display model. Is it alright?
xxxxxxxxxxxxxxx:~$ sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
NAME FSTYPE SIZE MOUNTPOINT LABEL MODEL
sda isw_raid_member 223.6G INTEL SSDSC2BP24
sdb isw_raid_member 223.6G INTEL SSDSC2BP24
sdc 223.6G INTEL SSDSC2BP24
sdd 223.6G INTEL SSDSC2BP24
sde 447.1G INTEL SSDSC2BP48
sdf 447.1G INTEL SSDSC2BP48
nvme0n1 372.6G
nvme1n1 372.6G
Do I need to install any additional driver to get it to work properly? Are there any benchmarks or verifications to test them?
ASouz7
aensidhe,
We will check this further. However, the latest version should have all the necessary files to work with your SSD.
Now, other than this, are you experiencing any issue with your SSD?
