Community
cancel
Showing results for
Search instead for
Did you mean:
srama16
Does Intel DC P3600 supports SGL?
Hi ,
We are using Intel DC P3600 800G drive in our storage array, does this SSD drive supports SGL feature?.
we are using intel SPDK while debugging we found the NVMe controller doesn't support SGL
(gdb) p ns->ctrlr->flags & SPDK_NVME_CTRLR_SGL_SUPPORTED
$1 = 0
Is there any setup or settings which we are missing to set the device to support SGL?
Please find the drive information below and let me know if you need more information.
# isdct show -a -intelssd 0
- Intel SSD DC P3600 Series CVMD714000AX800VGN -
AggregationThreshold : 0
AggregationTime : 0
ArbitrationBurst : 0
Bootloader : 8B1B0133
CoalescingDisable : 1
DevicePath : /dev/nvme0n1
DeviceStatus : Healthy
DirectivesSupported : False
EndToEndDataProtCapabilities : 17
EnduranceAnalyzer : Media Workload Indicators have reset values. Run 60+ minute workload prior to running the endurance analyzer.
ErrorString :
Firmware : 8DV101H0
FirmwareUpdateAvailable : The selected Intel SSD contains current firmware as of this tool release.
Subbu
Community Manager
Hello Subburajr,
We are engaging additional resources to address this request, we will be giving you updates as soon as we have them.
Nestor C
srama16
Hi Nestor C,
Thanks for the reply, I am waiting for the update from Intel regarding the query.
Thanks & Regards,
Subbu
srama16
Hi Nestor C,
Is there any update on this?. We need to take an important design decision based on this, I would appreciate if we get quicker answer for this.
Thanks & Regards,
Subbu
srama16
Hi Nestor C,
Subbu
srama16
Hi All,
Can anyone have an answer for this? If you have answer please reply to this query.
Thanks in Advance
Subbu
Community Manager
Hello Subburajr,
We do apologize for the delay, our team on holiday but now we have the response from them.
Basically, they confirmed that the drive does not support SGL.
Please let us know if you need to get any additional information about the drive.
Nestor C
srama16
Hi Nestor C
Thanks a lot for the reply.
Subbu
srama16
Hi Nestor C,
Is latest drives have SGL support? If so, what models does support SGL feature?.
Thanks in advance,
Subbu
Community Manager
Hello Subburajr,
After checking with our engineering team, we need to let you know that none of our NVMe* drives, including the latest ones, support SGL.
If you have any other question please let us know.
Nestor C
srama16
Hi Nestor C,
I have gone through some of the Intel NVMe SSD drive products, I can see DC D3600 specification mentioned that it supports SGL. Can you please confirm the same?. Please find the below link for the DC D3600 spec.
https://www.intel.in/content/www/in/en/solid-state-drives/ssd-dc-d3700-d3600-brief.html Intel® SSD DC D3700 and D3600 Series Product Brief
Subbu
Community Manager
Hello Subburajr,
Actually, that information you found is correct, you can verify it in these links:
- https://simplecore.intel.com/newsroom/wp-content/uploads/sites/11/2016/03/SSD-Fact-Sheet_URL-update-... Intel News Fact Sheet
- https://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ssd-dc-d3700-d3600-brief... Product Brief
- For each drive's specs, please http://ark.intel.com/compare/88740,88724 check this link.
Please let us know if you require further assistance.
Nestor C
srama16
Hi Nestor C,
I couldn't understand, the earlier reply you said none of the Intel NVMe* drives supports SGL even the latest one too.
Now the previous reply you agree with that DC D3600 supports SGL, can you confirm which are all the models that supports scatter/gather (SGL) IO ?
Subbu
Community Manager
Hi Subburajr,
Just to explain to you about the previous posts, we want to clarify that we were referring to the data center drives "P" series, none of those support SGL and that includes the latest versions (DC P4500 and DC P4600).
On the other hand, the data center NVMe* drives D3600 & D3700 seem to be the only ones with this feature support.
We apologize for the confusion and hopefully, this information is helpful for you.
Nestor C
