Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Does Intel Offer Worldwide Warranty Coverage?
Jump to solution
If I buy in US and bring it to my country, will I get warranty coverage from their distributor? Or will have to send back to US to get a service and would sending abroad make sense?
jbenavides
Hello TechnicGeek,
Intel® SSD's are covered by an international Limited Warranty. The warranty terms and conditions are dependent on the drive; you can find the Limited Warranty documents for the different Intel® SSD's in the following website: http://www.intel.com/support/ssdc/hpssd/sb/CS-029645.htm Intel® High Performance Solid-State Drive — Limited Warranties
As you can see from the documents, the warranty coverage for Intel SSD's is international and support for them can be provided in different regions, just keep in mind that some limitations and exclusions may apply by state, nation, province or locally.
To obtain warranty service for the Product (purchased in its original sealed packaging), you may contact your original place of purchase in accordance with its instructions, or you may contact Intel.
The contact methods for each region can be be found in the following link: http://www.intel.com/p/en_US/support/contactsupport Contact Support
For more information, please review the following websites:
http://www.intel.com/p/en_US/support/warranty Warranty Center
http://www.intel.com/support/ssdc/hpssd/sb/cs-031625.htm Intel® High Performance Solid-State Drive — Registration, Warranty, and Return Material Authorization (RMA)
jbenavides
Hello TechnicGeek,
