cancel
Showing results for
Search instead for
Did you mean:
Does SSD Optimizer consolidate free space (or defrag disk)?
Esteemed Contributor III
FYI:
The answer is no per tests.
Tested by running PerfectDisk v11 defragger analyse function before and after running SSD Optimizer on a X25-M G2, 02HD firmware, 80GB, Win 7, TRIM enabled.
Note: consolidating free space is aka garbage collection
1 REPLY 1
You are correct -- there is no background garbage collection when the drive is idling. The "trim" command merely lets the firmware know which logical block addresses (LBAs) no longer contain valid data ("dead" data).
When writes to the drive are done, the FW chooses where to write this data. This is when the position to write this data is selected and various pieces of of "dead" data are shuffled and eventually removed.
You can think of it as the SSD Optimizer uses Trim to effectively communicate more of the "dead" data, which will be defragged as part of subsequent writes.
