We are looking at getting some of the DC P3700 PCI-e 3.0 add in cards for some servers at work. Do you know if they work on PCI-e 2.0 slots? I thought it would be backwards compatible, but I read a review that it wasn't. Is there any official word?
Thank you.
Hello donflamenco, the Intel® DC P3700 supports PCI Express 2.0 but performance will be reduced.
Hello Joe,
Great. Thank you for the confirmation. We are excited to get them in and try them out.
Thanks again,
Rob
Do note that a uEFI 2.3.1 supporting bios is required. See the installation guide https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23929&lang=eng Intel® Download Center
Hello Joe,
Just installed the DC P3700 PCI-e in a HP DL360 G6, which only has a PCI-e 2.0 slot. I have RHEL 6.5 installed on the box (with RH's latest RHEL6.5 kernel).
We are not seeing the device.
"isdct show -intelssd" returns "No results".
I'll keep playing around with it, but it doesn't appear that the SSDPEDMD400G401 is backwards compatible with PCI-e 2.0.
Any other things I can try?
Rob
Thanks Warren,
Do you know if I need a system with UEFI 2.3.1 to support the DC3700 if I DON'T need it to boot?
We are fine with booting off of our normal harddrives, and want to use the DC3700 for db files.
I'm trying to get the SSDPEDMD400G401 working on a PCI-e 2.0 system and don't have any luck yet. We are running RHEL6.5.
Rob
I can only tell you what I have seen.
Intel DX58SO board latest available bios = 3 beeps (memory missing) but works fine when I remove the card
DQ57TM = same
DQ67EP (PCIe 2.0) = works with latest available bios and 64bit Windows plus PCIe NMVe driver
DH77MK? = works
I haven't tried Linux but I expect your difficulty is bios and hardware not the OS.
Thanks...
