Community
cancel
Showing results for
Search instead for
Did you mean:
FCorn4
Does the SSD 750 series is compatible with C612 chipset ?
I recently bought a Dell T7810 workstation with 2 xeon E5-2690v3 cpu. I want to put a very fast SSD like the Intel 750 series on this system that is having an Intel C612 chipset. It is compatible with the X99 chipset but what about the C612 that is a very similar chipset than the X99 ? Will there be a driver soon to support the C612 chipset ? Will there be a product similar in performance compatible to the C612 chipset ? Any product suggestion ?
jbenavides
Hello BuGGzzZZ,
The http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-750-spec.pdf Intel® SSD 750 Series is a high performance SSD, designed for PC enthusiast and workstation systems.
This drive does not require a specific chipset, however, it has some requirements that are normally available in systems with a newer chipset.
We strongly advise you to check with the computer manufacturer to validate your system meets the requirements, and if there are any compatibility implications.
- PCIe* Gen3 x4 compatible connector (SFF-8639 or HHHL x4).
- UEFI* 2.3.1 or later
- Windows* 7, 8 or 8.1.
We would like to mention that the Intel® SSD 750 Series is considered a high performance consumer product.
If you plan to use your workstation with a data center/server workload, or using a server OS version; you might want to consider a Data Center SSD, such as the http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3500-seri... Intel® SSD DC P3500 Series, http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3600-spec... Intel® SSD DC P3600 Series or http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... Intel® SSD DC P3700 Series.
Data Center SSDs have enhanced performance, endurance and data protection that make them optimal for Enterprise systems.
There are some documents and validated combinations about Intel Data Center SSDs for Dell* Servers in the following link:
http://www.intel.com/support/ssdc/hpssd/dell-support.htm http://www.intel.com/support/ssdc/hpssd/dell-support.htm
WKoeh
I just got off the phone with SuperMicro and they say they have not tested the PCIe SSDs with any of their C612 based motherboards although they meet all the specifications listed by jonathan_intel.
lgrac4
I bought asus Z10PE-D16WS motherboard and try to install 750 ssd and i couldn´t boot from the drive on windows 7. windows 8 and windows 8.1. It seems the bios from the motherboard doesnt reconize intel 750 as a boot drive. Its is weird because it has all the requirements and the new version of the bios says it suports NVME drives....If someone could help I am in doubt if i shall return the product from the store that i bought or try a support.....
ASouz7
Hello Leonardo_graca,
The Intel® SSD 750 Series is a PCIe NVMe device. Booting from it requires uEFI, 64bit OS and NVMe driver.
In this link, you will find the list of compatible motherboards that will work with the Intel® SSD 750 Series: http://www.intel.com/support/ssdc/hpssd/ssd-750/sb/CS-035484.htm Intel® SSD 750 Series — Tested Motherboards
You may also want to take a look at this other link as well:
http://www.intel.com/support/ssdc/hpssd/ssd-750/sb/CS-035483.htm?wapkw=intel+ssd+750+series Intel® SSD 750 Series — Frequently Asked Questions (FAQ)
http://www.intel.com/support/ssdc/hpssd/ssd-750/sb/CS-035496.htm Intel® SSD 750 Series — Before You Buy
lgrac4
Ok only x99 and z97 motherboards at the list....Do you think the P3600 series will boot in my motherboard?Does it have a list of tested motherboards for the p3600 series?At Asus web site it says the p3600 400 giga and 800 giga is qualified component. But i need to know what Intel says about de p36000.....I have only 2 days to exchange my product....
ASouz7
Leonardo_graca,
We would like to inform you that we cannot guarantee that the Intel® SSD DC P3600 Series will be bootable from all motherboards using the Intel® C612 Chipset. This capability would have to be confirmed with the motherboard manufacturer. On our best effort to help you with this, we do have these two documents that explain the steps required to boot from an Intel® PCIe* NVMe* Drive. Please check the links below as they contain information that might help you.
http://www.intel.com/support/ssdc/hpssd/sb/CS-035481.htm Intel® High Performance Solid-State Drives — Booting an NVMe* PCI Express* Solid State Drive
http://downloadmirror.intel.com/23929/eng/Intel%20SSD%20Data%20Center%20Family%20for%20PCIe%20Instal... Intel® Solid-State Drive Data Center Familiy for PCIe* P3700, P3600 and P3500
JLawd
Hi, I have a dual Xeon 2695 V3 and recently I purchased an Intel SSD 750 Series PCIe. Is this drive working with S2600CW2 motherboard? I need to boot from the SSD.
Many thanks
AP16
Valued Contributor III
Update BIOS of MB up to https://downloadcenter.intel.com/download/25363/S2600CW-BIOS-and-Firmware-update-for-IDA-OFU-WinPE https://downloadcenter.intel.com/download/25363/S2600CW-BIOS-and-Firmware-update-for-IDA-OFU-WinPE at least for NVMe support. You should boot in UEFI mode with disabled CSM (check the other server parts, like separate network adapters and storage controllers for native UEFI support). If current OS was installed in Legacy mode, you should install OS clean.
JLawd
Hi JFFulcrum,
I'll try it, thanks.
Can I update firmware from the BIOS itself?
AP16
Yes, upgrade utility is available as UEFI app too. Place UEFI tool and BIOS file image on flash drive and follow instructions from http://www.intel.com/support/motherboards/server/sb/CS-035564.htm http://www.intel.com/support/motherboards/server/sb/CS-035564.htm
