Community
cancel
Showing results for
Search instead for
Did you mean:
DMing2
Does the SSD DC S3520 support in storage programming?
are there components such as CPU, RAM ,etc inside the SSD , and interface which support some easy programming in it?
Community Manager
Hello DuMZ,
If we understand your request correctly you would like to use an Intel® DC SSD S3520 Series as a compute module to perform some basic programming tasks.
Please keep in mind this falls outside of our support scope, we cannot recommend this usage as it may https://www.intel.com/content/www/us/en/support/memory-and-storage/data-center-ssds/000020953.html void your warranty.
Our recommendation would be to look into our Intel® Edison Compute Modules or contact the Resource & Design Center:
- https://software.intel.com/en-us/iot/hardware/edison Intel® Edison Compute Module.
- https://www.intel.com/content/www/us/en/design/resource-design-center.html Resource & Design Center for Development with Intel®.
- https://www.intel.com/content/www/us/en/embedded/embedded-design-center.html Hardware, Software, and Solutions for Embedded and IoT Developers.
We hope this information helps. If this is not what you're looking for, do let us know.
Carlos A.
